That looks reasonably nice. Its also using discrete diodes rather than bridge rectifiers so you've got a lot of flexibility in how you configure it. e.g:
Omit diodes D2, D4, D5 and D7, cross jumper AC1 to AC3 and AC4 to AC2, and fit a terminal for the center tap to the ground end of the D4, D5 footprints, and you've reconfigured it as a single bridge fed by a center tapped secondary, as per your original post.
