The big limitation for a multirange TIA will be the capacitance as the Analog link shows, though by keeping the unused paths biased with a buffer that could be reduced IMO (which the Analog link doesn't show).
You'll probably want to buffer the input voltage any way so you can use a more heavy duty input protection than the opamp input diodes, something which can divert enough current for long enough to blow a fuse. Though just sacrificing the circuit if you make a mistake is always an option too, the components aren't that expensive.
