I built my first PCB (hobbyist only), and I added some 2.54mm sockets, that I often use for probing with the oscilloscope.
The problem I have is that I don't want to be holding the probe, so I usually add some wires and use the GND clip, but this creates large ground loops and add a lot of noise into the scope, which for some measurements is a problem.
What other alternative footprints/sockets/... can I use to make it easy to hook the scope, reducing ground loop/noise?
Thanks!
