No, I asked for help with the PCB layout, not the physical design of the boards, mechanics, or assembly methods. I have been given advice on everything BUT the PCB layout.
I gave you reasons why your suggestions were not relevant or feasible, so the reasons are not "unknown". I have explained everything in detail.
My specific questions are:
-Are the vias I have placed sufficient? I believe I have provided a return path for everything, there are no loose copper islands, is there anything else?
-Is there anything else that can cause noise issues?
This should be a very simple question, but if you are not qualified to answer, just say so. I came here to ensure that the PCB's don't look amatuerish, but I seem to only be getting answers from amateurs. If you could explain WHY I'd need a 4-layer board and two internal ground planes it would help a lot because I'm not in the habit of doing something on the sole basis of "some rando said it".
The connecters are not really a serious issue. Everything is securely mounted, and the mechanical tolerances are down to pluss/minus 0.1-0.2mm.
The connectors are there to aid in assembly, period! I am not gonna run fricking wires all the way to the LED board because I can't solder something already mounted to the 3d print. PLA melts like butter at 60 degrees and printing in Nylon or ABS won't solve that issue. Soldering irons and plastic don't mix.
Now, what about the PCB layout? Specifically the traces, NOTHING ELSE. Are you qualified to answer or not?
Just to clarify: I cannot move any components as their position is constrained and dictated by the mechanical design, as in ANY other product. I will NOT integrate any components onto the board because that defeats the purpose of the product. These are simply carrier boards, nothing else. The user must be able to assemble and disassemble the drone for maintenance or component replacement without soldering (modularity).
The electronics package needs to plug into the rest of the structure as this is the last step of assembly.
Your suggestions are based on the presumption that I am making a consumer drone like a bloody DJI product, or that I can just secure shit with double sided tape and wires. This is a DIY kit build and a sensor development platform as I have explained over several posts.
Now if you wanted to integrate all the electronics, you could design your own PCB for this. That is the entire purpose behind this project. You can integrate any electronics you want. I am just providing a simple and powerful drone for you to tinker with at a very low price point. If you like quads, fine. Have all your electronics exposed. Here they are all protected within a robust plastic structure that would survive a light crash with only superficial, or very limited damage.
