Author Topic: Looking for possible MOSFET identification  (Read 321 times)
Offline OneGeekGuyTopic starter
« on: July 26, 2024, 05:47:49 pm »
Hi all,
A motherboard blow up due to a possible un expected over voltage in the input, after short looking, I noticed an area which was damaged, looks like they are MOSFETs due to the fact they are close to a possible PMIC and Inductors, the point is that after taking a look to the numbering on other MOSFET close to the damaged one:
7534NL1G12
Could be an AON7534, but the rest of the PN, either I cannot find it, or it is not critical, do someone knows a bit more regarding how AON Semi name their mosfets? Could I replace it for a AON7534?
Any help will be welcome!
Thanks!!
Online ZenHombre
Re: Looking for possible MOSFET identification
« Reply #1 on: July 26, 2024, 07:39:54 pm »
Found this, their marking guide. you should be good to replace it with AON7534.
https://www.aosmd.com/sites/default/files/res/markings/AON7534.pdf
The following users thanked this post: OneGeekGuy
« Reply #2 on: July 29, 2024, 03:14:58 pm »
Thanks! Just what I needed, so I will move forward with that. Thanks again!
