Author Topic: Drive NOKIA 5800 LCD  (Read 1125 times)
Offline FAMELCTopic starter
  • Country: ir
« on: December 29, 2019, 06:59:35 pm »
Hi.
I want to drive NOKIA 5800 LCD with microcontroller but my problem is pinout details of LCD connector.
I mean, I have no documents or datasheet of it to undrestand about timing and protocol of LCD pins.
I also downloaded the relevant files like "Nokia service manual"(LCD pinout attached), but i cant undrestand CDP0 ck- or CDP0 ck+??
Why positive and negative is used??
Thanks a lot.
Offline coromonadalix
Re: Drive NOKIA 5800 LCD
« Reply #1 on: December 30, 2019, 12:06:18 am »
The following users thanked this post: FAMELC
Offline Prehistoricman
« Reply #2 on: December 30, 2019, 03:04:58 am »
Possibly LVDS (low voltage differential signals). One wire uses positive logic while the other uses negative logic.
  • Country: ir
« Reply #3 on: January 01, 2020, 07:55:21 am »
Thanks for answer
What is the voltage level for each pin?
