I have bought the Dot matrix Too , would you mind sharing your code and a brief explanatation
thanks in advance
shailesh
Here's the XC32 project. It is pretty crude, so sorry about the lack of comments, but it should be pretty straight forward. The DateTime library doesn't support decrement of time as I only needed increments, but can be pretty easily added.
Basically there's an interrupt trigger on the UART (GPS) that updates the led modules. There is supposed to be a DS3232 backup when lacking GPS data, but didn't need to implement it as it works pretty good once it gets a lock. There are still some kinks but nothing mayor
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
*edit* managed to introduce a bug cleaning the code dealing with the ds3232 or gps. Clock suddenly stopped ticking on the night stand. I will have to go through it and post an update
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
