Author Topic: Self Powered Circuit Generator  (Read 1056 times)
Offline artanisTopic starter
« on: July 30, 2024, 06:42:01 am »
Hello, I am interested in making a self powered switch that can send a small signal to a receiver, something similar to this one:
https://www.dfrobot.com/product-2568.html
Bigclive has a taredown video of a similar mechanism here:
Does anybody know if I can get the components for that generator ready made or are they a custom component? I have no clue what to ask google in order to get to at least something similar that I can order.
Any clues are highly appreciated.
Offline Kim Christensen
Re: Self Powered Circuit Generator
« Reply #1 on: July 30, 2024, 04:23:37 pm »
What he shows at the 7:00 mark definitely looks like a custom part. That would be hard to find. Searching for "kinetic switch" just gets me the finished products.
EDIT: Part number on coil looks like DPM4175 or maybe DPM4173
« Last Edit: July 30, 2024, 07:51:05 pm by Kim Christensen »
Offline Benta
« Reply #2 on: July 30, 2024, 06:51:54 pm »
The general term for this kind of thing is "energy harvesting".
It can be a lot of things, kinetic, thermal, electric, optical....
Online Phil1977
« Reply #3 on: July 30, 2024, 07:44:45 pm »
Do you want to wirelessly send a RF-signal?
Then you probably should rely on off-the-shelf products like in Bigclives video.
Or do you just want the power generator? Then you could "misuse" a lot of components, like mentioned by Benta or a stepper motor, a loudspeaker coil, a peltier element, a piezo crystal, ...
« Reply #4 on: July 30, 2024, 09:03:42 pm »
that's a good clue, I totally missed it  :palm:
Indeed my circuit will also send some rf signal and I am interested to see if I can build one myself as a hobby project.
Currently I am interested only in the power generator and I would much prefer to find a solution that I could purchase somewhere. Thanks for the idea on how I could cook up my own from component "misuse"! this will come in handy if need to make one myself.
Offline BrianHG
« Reply #5 on: July 30, 2024, 10:56:59 pm »
Try to disassemble a few small DC relays for a compact pre-fab coil with metal core and adapt your own moving magnet to generate voltage.  Expect to use a higher voltage relay like 24v or 48v to make only 3v for a short instant with a load on the coil.
Online Phil1977
« Reply #6 on: July 31, 2024, 08:42:52 am »
Or just use one of the small but powerful loudspeakers e.g. from a dead bluetooth-boombox.
Remove the membrane as far as possible without destroying any copper wire. Then put a heavy coin in the middle and just vibrate everything.
The voltage you get from these speakers is quite low, but it´s possible to rectify it with a shottky diode and run e.g. a joule thief oscillator with a small LED. It´s quite fascinating where you can "harvest" power that way.
« Reply #7 on: July 31, 2024, 10:38:01 am »
Thanks for the ideas! will experiment and see where I go with this.
« Reply #8 on: July 31, 2024, 10:41:24 am »
FOUND SOMETHING!  ;D
https://www.aliexpress.com/item/1005005936566868.html
EDIT: Got a bit too excited, unfortunately it's no longer available  :-\
« Last Edit: July 31, 2024, 10:46:03 am by artanis »
« Reply #9 on: July 31, 2024, 02:29:52 pm »
I managed to find a manufacturer's site which has more part numbers for you to search for.
The name almost looks like Limptech.   ;D
« Reply #10 on: July 31, 2024, 03:35:04 pm »
nice one! getting closer and closer  ;D
Offline JimRemington
« Reply #11 on: August 02, 2024, 02:02:10 am »
Here is another self-powered switch manufacturer:
https://www.enocean.com/en/product-category/kinetic-switches/
The following users thanked this post: artanis
