Author Topic: connector range that work board-to-board, wire-to-board and wire-to-wire?  (Read 2421 times)
Offline ChendyTopic starter
Was wondering if anybody knew a connector range that work board-to-board, wire-to-board and wire-to-wire all at the same time? I haven't found one. I'm guessing some creative thinking will be needed here.
- ideally polarised
- 1A or more,
- small size, say 1.5 to 3.5 mm pitch (or max current 5A as a gauge of style)... stardard 2.54mm dupont/mini-pv size would be great.
- 4 poles or more
current notes:
- 2.54mm bump/polarised dupont/mini-pv housings with bump/polarised nearly work. However wire-to-wire has no proper female housing part, male/female crimp pins are used, which isn't ideal.
- I like Molex SL, but no female header for board-to-board. I guess I could probably use standard (unpolarised) 2.54mm pitch headers
Cheers
Offline Ste
Re: connector range that work board-to-board, wire-to-board and wire-to-wire?
« Reply #1 on: November 13, 2015, 11:20:13 pm »
Check out the Hirose DF11 series and see if that has what you need:
https://www.hirose.co.jp/cataloge_hp/en_DF11_20130411.pdf
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: November 14, 2015, 03:12:23 am »
Also JST do cable mount connectors that mate with XH headers - confusingly the series has a different name (XA? not sure from memory). You should be able to mate an XH male PCB header with a generic 2.5mm female socket
Day Job: Mostly LEDs
« Reply #3 on: November 16, 2015, 02:09:37 pm »
Thanks guys,
@ Ste
Thanks looks interesting.
@ Mike
Yes, the JST XH mate with the JST JQ range. But AFAIK, there is no proper wire-wire XH connector - people seem to be soldering+heatshrinking
« Reply #4 on: November 17, 2015, 01:21:00 pm »
There definitely are some third-party wire-male cons that  mate with XH - ISTR seeing some JST ones that weren't advertised as such that would actually work. XA maybe?
Offline kony
  • Country: cz
