Author Topic: Does a piezzo buzzer needs a protection diode  (Read 14253 times)
Offline rggmirandaTopic starter
  • Country: uy
« on: July 23, 2015, 12:15:31 am »
The question is really simple, i need to drive some piezzo buzzers from a transistor, and i would like to know if they need to use a diode protection like if they where an inductive load, i know they are not, but, even tough i read about it, i am not sure if piezzos cannot generate the same issue, please clarify me on that. Thanks!
Offline BennVenn
    • BennVenn's site
Re: Does a piezzo buzzer needs a protection diode
« Reply #1 on: July 23, 2015, 12:20:31 am »
Is it a buzzer (has the oscillator circuit built in) or just the piezzo element (disc)?
  • Country: uy
« Reply #2 on: July 23, 2015, 12:26:12 am »
I belive it has the oscillator built in, i just connect it to 5v dc
Offline BennVenn
    • BennVenn's site
« Reply #3 on: July 23, 2015, 01:04:38 am »
then don't bother with a protection diode
  • Country: uy
« Reply #4 on: July 23, 2015, 01:13:00 am »
Ok, thanks you a lot, anyway, just for further knowledge, in the other case in which i had the piezzo itself, what would happen?
Offline BennVenn
    • BennVenn's site
« Reply #5 on: July 23, 2015, 01:55:39 am »
Well that is intersting, the piezzo would be capacitive not inductive so you wouldn't get the back EMF that you would with a coil however if you drove it to resonance who knows!! Would be interesting to see on a scope
  • Country: uy
« Reply #6 on: July 23, 2015, 02:15:38 am »
For now, as i need it with the driver i will just avoid the diode, further on i may open one and check it with the scope, who knows maybe it can be harmfull, i will tell you the result, if you do it first tell me!
Thanks for the info
Offline TheMG
« Reply #7 on: July 23, 2015, 04:59:51 am »
I've used such buzzers in many projects and have even seen them used in many very expensive pieces of commercial equipment, no diodes on any of them, never been a problem.
Offline zapta
« Reply #8 on: July 23, 2015, 06:20:24 am »
You also need to consider what will happen to your circuit if you will hit the piezo and it will generate high voltage exceeding less say Vce. That is the piezo is also a voltage source, not just load.
« Last Edit: July 23, 2015, 06:23:09 am by zapta »
Offline Zero999
  • 0999
« Reply #9 on: July 23, 2015, 07:52:01 am »
A piezo buzzer with built-in driver contains a transistor oscillator and a transducer with a feedback pin which makes building the oscillator easier - it's just an amplifier with the input connected to the transducer's feedback pin.
The only time a piezo buzzer contains a coil is to boost the voltage to get more sound but still no diode is needed as the transducer absorbs the extra voltage.
Offline zapta
« Reply #10 on: July 25, 2015, 06:20:50 am »
From Murata:
In order to protect the IC from back electromotive force generated by a piezoelectric sound component, consider connecting a Zener diode in parallel with the piezoelectric sound component and Rp if necessaryFrom
http://www.murata.com/en-us/support/faqs/products/sound/sounder/char/sch0001
« Last Edit: July 25, 2015, 07:47:02 am by zapta »
Offline Zero999
  • 0999
« Reply #11 on: July 25, 2015, 09:36:10 am »
From Murata:
That only applies to piezo transducers which don't include a built-in oscillator.
Offline Psi
« Reply #12 on: July 26, 2015, 01:07:32 am »
Here's a piezo being driven directly from a AtMega I/O pin at 3.5khz
Looks like it will be touching the clamping diodes on switch-off, about -1V
« Last Edit: July 26, 2015, 01:10:55 am by Psi »
