Somebody has been smoking too much <something>. That circuit is INSANE! two op-amps, a switching power supply controller, several assorted transistors, 4 voltage sources, and on and on, for 6 W?
There are single chips that will do this very nicely, possibly with an additional resistor or two to set the parameters.
Jon
