Author Topic: Do you verify the netlist before PCB layout?  (Read 18904 times)
Offline zaptaTopic starter
« on: February 05, 2014, 01:04:26 am »
When you are done with the schema and ready to start the board layout, do you verify the netlist? I mean manually over the netlist and verifying each net and node?
Offline Rerouter
Re: Do you verify the netlist before PCB layout?
« Reply #1 on: February 05, 2014, 01:29:32 am »
kicad has an option to cleanup unconnected tracks in its schema package, equally DRC will point out any unconnected pads (you have to specify "do not connect" to make it not flag (modifying pins to the right type for DRC is helpful here)
with these tools i am confident that i wont need to verify line by line, and i use the schematic not just the net-list while laying out (to keep in mind what needs to be kept close and low noise etc) which is a second chance for me to pick up any issues in my schematic.
Offline c4757p
  • adieu
« Reply #2 on: February 05, 2014, 02:44:48 am »
If the netlist isn't a perfect listing of what touches what in the schematic, there's a bug report to be filed...
« Reply #3 on: February 05, 2014, 04:10:16 am »
You cannot derive the correct netlist just by looking at a schematic.
In eagle for example, hidden shared names can make a connection and misplaced network names can look as connections but are not.
Offline rfbroadband
« Reply #4 on: February 05, 2014, 04:26:16 am »
Usually you run what is called DRC (design rule check). The following pics provide an idea of all the things you should verify and check. All the CAD tools are slightly different, but I assume every schematic capture has the ability to run these checks automatically.
When you are done, you better have a perfectly clean DRC error list like the one below...
Date and Time : 02/04/14 22:22:16
Checking Schematic: SCHEMATIC VBus Mon
Checking Electrical Rules
Checking For Single Node Nets
Checking For Unconnected Bus Nets
Checking Off-Page Connections
Checking Pin to Port Connections
Checking Physical Rules
Checking Pins and Pin Connections
Checking Schematic: SCHEMATIC Demo Design
INFO(ORCAP-2242): Checking Incorrect Pin Group Assignment
Report for Invalid References
Report for Duplicate References
Checking Entire Design: Demo Design
Checking Power Pin Visibility
Checking Normal Convert View Sync
INFO(ORCAP-36105): Checking Missing Pin Numbers
Checking Device with Zero pins
INFO(ORCAP-36101): Checking Missing PCB Footprint Property
Checking Name Property for Hierarchical Instances
INFO(ORCAP-2211): Check High Speed Properties Syntax
INFO(ORCAP-2212): Check Power Ground Mismatch
Reporting Unused Refdes in multiple part packages
Part                          Quantity                          Reference
Offline uoficowboy
« Reply #5 on: February 05, 2014, 04:58:39 am »
If I'm not doing the layout, I definitely will check the netlist. If I'm doing the layout myself, it's less important but I may still check it.
It's great for catching things like slightly misnamed nets (ie SPI_SCK and SPI-SCK).
Offline AlfBaz
« Reply #6 on: February 05, 2014, 05:14:46 am »
...and here I was wondering why I never get errors  ;)
Offline HackedFridgeMagnet
« Reply #7 on: February 05, 2014, 06:49:32 am »
it seems like you're just saving your errors up for a rainy day.
Offline rfbroadband
« Reply #8 on: February 05, 2014, 06:55:12 am »
:-) which tool is that ?
Offline AlfBaz
« Reply #9 on: February 05, 2014, 06:57:32 am »
Altium
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #10 on: February 05, 2014, 10:13:48 am »
apart from the mentioned, diptrace way of highlighting all lines in the net realtime while in edit/schema/pcb mode is pretty handy, not some arbitrary disconnect of lines union that should not in the care of ee engineers.
Offline free_electron
    • SiliconValleyGarage
« Reply #11 on: February 05, 2014, 03:13:48 pm »
Altium
that is the default option of you use a pirated copy
Altiums checker is very good. in all my board designs i have never had problems with missing connections. If the schematic is correct the board is correct.
Offline AlfBaz
« Reply #12 on: February 05, 2014, 04:15:44 pm »
Altium
Get bent free... It was a joke, hence the winky smiley face
Offline nctnico
« Reply #13 on: February 05, 2014, 04:38:25 pm »
That sounds more like a problem in the CAD software / schematic than the netlist. I mostly use Orcad and some old libraries have hidden power pins. I usually change these components to have all pins visible.
During layout I usually change the colors of the ratsnests for certain nets like power, ground or nets with high voltages/large currents. That also gives some insight in how everything is connected.
Offline andyturk
« Reply #14 on: February 05, 2014, 05:42:00 pm »
Hey rf, your last screen grab of the ERC matrix looks like it's flagging an error when you connect an "input port" to an "output".
Why is that an error?
Offline rfbroadband
« Reply #15 on: February 05, 2014, 05:49:16 pm »
I don't recall why this flag was set in this particular case.
« Reply #16 on: February 05, 2014, 06:25:17 pm »
bingo. hidden pins should be made illegal and fined !
Offline c4757p
  • adieu
« Reply #17 on: February 05, 2014, 06:45:45 pm »
Fined? I say it's time to bring back public corporal punishment...
« Reply #18 on: February 05, 2014, 10:58:38 pm »
YAY . stocks, tar and feathers.
Offline TerraHertz
    • It's not really a Blog
« Reply #19 on: February 06, 2014, 08:41:14 am »
Back when I was still doing PCBs, (Protel, Orcad) I'd generally print a copy of the schematic, and the netlist, and use a hi-lighter to make damn sure they matched. Every now and then there'd be an error. Bad parts in the library, mistyped net names, etc.
But the really useful sanity check was later, after the board layout was done. I'd delete the netlist in the CAD program, leaving just the copper layout and components. Then tell it to rebuild the netlist from the copper. I think it was Protel that had a feature to do that, and then compare the resulting netlist to the original one.
*That* tended to find some surprising errors.
Thanks to doing  that, I had pretty good luck with boards working first time.
In general, if you're doing commercial PCB design and you find yourself wondering whether to put in a few hours tedious work with a hilighter, or skip that and just go ahead and send out some gerber files that will take weeks of turnaround and cost a pile of cash, fingers crossed they are OK, then you shouldn't be doing commercial PCB design.
It's also good to have someone else review both your schematic and PCB layout.
Offline nctnico
« Reply #20 on: February 06, 2014, 11:32:42 am »
What helps is to turn everything off except the rats nest. That way you can see whether every net has been connected. Most layout software has a feature to show the number of unconnected nets. In some packages (for example Orcad layout) this doesn't work quite well.
Offline peter.mitchell
« Reply #21 on: February 06, 2014, 01:49:33 pm »
Altium
I'm not sure what is implied here?
It appears to me that he has disabled all warnings for all violations, for what appears to be pure laziness.
What does this have to do with Piracy? Do the people who provide the pirated software set the settings like this in hopes to spite you?
I do agree about the checker though, it is very good, I have had no issues ever aside from those related to user error. Even vast updates to schematics from changing the PCB and pushing the change to the schematic has been trouble free (I have encountered errors/issues with other programs here).
Agreed, it was one of the first things I learned when looking at schematics, this is a brief summary of a conversation I had with a colleague whom I tended to avoid afterwards.
Q "Where are the supply pins on that 7400 series?"
A "Oh, they're taken care of, don't worry."
Q "What the heck do you mean taken care of, don't worry? What if i want to see what it's connected to, or make sure it IS connected or change where it's connected? Why does it have to be hidden? If it is too annoying to have on each part of the chip (assuming multi part component EG, IC1A, IC1B, IC1C, IC1D) can't you at least have it as another part of the component off on a different page or somewhere more discreet?"
A "Nah, why would you want to do that anyway?"
I am quite trusting of the checker in Altium, but that doesn't mean I don't manually check as much as I can before I send out the gerbers.
Usually i print the gerbers out on A3 transparencies, then join the dots with different coloured dry erase markers.
Offline Gribo
« Reply #22 on: February 06, 2014, 02:26:50 pm »
Depends on the design. On a 4 or 2 layer cheap board, I usually don't bother. On an 8 layer, limited production run, I check every net. My method is the same as mentioned above, with transparencies, markers, and another engineer for double checks.
I am available for freelance work.
« Reply #23 on: February 06, 2014, 02:34:11 pm »
I'm pretty pedantic on ALL boards, time is money, and if it takes me a few hours to triple check a board, vs a week and a bunch of money for a re-spin, it's worth it.
Offline AlfBaz
« Reply #24 on: February 06, 2014, 03:46:17 pm »
Emoticons just don't seem to be big enough for some!
I went through and cycled them all to green just to just to take a screen capture for a dumb "dad joke" post, hence the  ;) emoticon.
Obviously I pressed cancel on the DRC dialog after doing so. If anybody was that lazy, surely they'd just ignore the DRC markers
Then it seemed to be implied that I had pirated software and I took offense
