Author Topic: Cheap SPI MRAM - any experience with PM004MNIATR?  (Read 393 times)
Offline blinkenTopic starter
« on: May 25, 2024, 07:48:46 pm »
I'm looking for options for cheap (<$4), SPI-addressable, 1-4Mbit of fast memory for a new project and I came across these SOP-8 MRAM modules from Shanghai Siproin Microelectronics:
Does anyone have any experience with these parts? The cheapest option @ digikey.com for a 2Mbit SPI MRAM module is USD $6.67 (qty 1000), so this would be a substantial improvement.
Offline Benta
Re: Cheap SPI MRAM - any experience with PM004MNIATR?
« Reply #1 on: May 25, 2024, 09:15:41 pm »
Why does it have to be MRAM?
F-RAM or nvSRAM are much more common.
https://www.infineon.com/cms/en/product/
Offline MT
  • Country: aq
« Reply #2 on: May 25, 2024, 09:33:07 pm »
50Mhz max is not fast, even SPI Psuevdo RAM(old school DRAM) does at least 133Mhz
« Reply #3 on: May 26, 2024, 09:48:35 am »
Thanks for the suggestion! I'd totally take FRAM (or any other fast-write technology), but the cheapest Infineon part I can find is FM25V20A-PG, USD4.60 @ digikey.
I mostly just need fast writes to an SPI or I2C memory block to buffer some collected data for processing - 50MHz is plenty fast. Something like the Microchip 23LCV1024-I/ST actually looks pretty good though.
