Author Topic: Help Identifying this part  (Read 713 times)
Offline manytoolsmikeTopic starter
  • Country: ae
« on: August 15, 2022, 11:36:36 am »
Hello Everyone,
These components where in series with an ultrasonic transducer. It was all potted so this was the best I could manage to not destroy them. I am assuming they are a fuse. The best I can read the markings say...
"250 V" and "SFF13F" or "SFFUS" the markings where mostly removed by the potting compound. I tried reading the mirrored image stuck to the potting. I included the un-mirrored image as well.
Dimensions are 11mm long and 5mm diameter. If anyone can identify the brand that would be a huge help.
Thanks all!
Mike
Re: Help Identifying this part
« Reply #2 on: August 15, 2022, 12:20:54 pm »
One time thermal fuse, Littelfuse has those, and the temperature is probably around 155C if the numbers are right.
https://www.digikey.com/en/products/filter/thermal-cutoffs-thermal-fuses-and-breakers/146?s=N4IgjCBcpgbFoDGUBmBDANgZwKYBoQB7KAbRAGYwB2MATgAYQBdAgBwBcoQBldgJwCWAOwDmIAL4EATPQAcshCGSR02fEVLh6AAgCCzNp0ggAqkIHsA8igCyONFgCufHBPHigA
will take you to the selection for Digikey USA for them, you will just have to read up the temerature on the line below the 250V marking.
  • Country: ae
« Reply #3 on: August 16, 2022, 03:42:24 am »
Thanks for your help! You guys are awesome. I tried google image search and got nowhere.
