Ok, then you have to know that with current MCU that is trying hard to generate and measure output voltage and current, and draw that on display without assistance of graphical controller/accelerator (which doesn't exists
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
) you cannot expect miracle.
Here is few examples of signal measured with scope. Pulse with D=0.3, 100 Hz, programing voltage of 2.5 V (i.e. full scale) and DC offset on the half (1.25 V) is show below. You can see that rising speed is about 20 V/ms, and falling about 10 V/ms
without load attached.
![](https://i.imgur.com/HVelqDgl.png)
... ramp with same frequency and amplitude is 2 V / 1 V DC offset:
![](https://i.imgur.com/Ovk1Tp7l.png)
... sinewave with same frequency and amplitude:
![](https://i.imgur.com/4nibWp0l.png)
It's clearly visible that such frequency is too high for analog part of the PSU, sinewave with lower frequency, e.g. 60 Hz looks much better:
![](https://i.imgur.com/I9pEnz2l.png)
But on the PSU display you can expect even with the fastest refresh rate od 10 ms (i.e. 10 drawings/sec) a nebulous graph:
![](https://i.imgur.com/87epHfzl.jpg)
You have to considerably lower the frequency to get meaningful results on the display, e.g. 5 Hz sinewave:
![](https://i.imgur.com/mwxBLhrl.jpg)
