Author Topic: safety of Chanies line to 3.3 v converter  (Read 1269 times)
Offline johananTopic starter
« on: January 03, 2016, 06:38:47 am »
I wonder if any one tested these small , very low cost converters for safety.
http://www.aliexpress.com/item/5PCS-Lots-AC-DC-Power-Supply-Buck-Converter-Step-Down-Module-3-3V-500mA-SG231-SZ/32423033877.html
While the price and size are very attempting, I don't have the equipment to test how well isolated they are. I don't care much about EMI for my hobby projects, but safety is another story.
Johanan
Offline Ian.M
Re: safety of Chanies line to 3.3 v converter
« Reply #1 on: January 03, 2016, 06:56:30 am »
Its a cheap chinese PSU.  The only way to tell for certain is to Hi-Pot test then tear one apart and measure all the clearance and creepage distances, including those for the inter-windng insulation of the transformer.  However the track running under the optocoupler on the back of the board compromising the creepage distance isn't a good sign.
« Reply #2 on: January 03, 2016, 01:42:50 pm »
I will be happy to see Dave doing a video on this  ;)
Offline djQUAN
  • Country: ph
    • My DIY website
« Reply #3 on: January 03, 2016, 02:18:29 pm »
If you are looking for a vid on one specifically on the supplies you bought then get some sent to him for a 2min teardown. If you just want to see cheap powersupplies torn apart, Bigclive has some in his channel
https://www.youtube.com/user/bigclivedotcom/videos
