Author Topic: DIY Metcal 13.56 MHz RF Supply  (Read 362547 times)
Offline parasole
  • Country: md
Re: DIY Metcal 13.56 MHz RF Supply
« Reply #550 on: March 11, 2021, 07:29:13 am »
Continue design study  8)
mamalala design could be improved by simply adding pre-amp stage (as in Sergey design) which will solve the driver overload issue and will raise output power.
Another aspect is the output transistor blow-up at the power-off time, which is a well-known phenomenon in high power RF amplifiers, that is the energy accumulated in the output filter which applies to the closed transistor and is well higher than its drain breakout voltage. In sergey design a TVS is used which is OK at this relatively low frequency, but a better solution is simple to use a transistor with a higher breakout drain voltage.
One common technics used in industry is to taper drive oscillator signal down before switching it off, which means implementing soft power off in firmware. Here same might be done by driving down the output stage power supply.
Otherwise, two designs are equal, probable a little bit more tweak might be done by optimizing low pass filter design...
« Last Edit: March 11, 2021, 07:32:24 am by parasole »
Offline rfmerrill
« Reply #551 on: March 11, 2021, 08:24:07 am »
I don't know about that. Sergey's design uses a power transistor (STP19NF20) with 3x current rating and 1/3 Rds(on), but also 3x gate charge, and that is what necessitates the preamp stage. The IRFP540 design you mention uses a gate driving transformer because the IRFP540 has even higher gate charge than that (150 nC vs 8 for the IRF540 and 24 for the STP19NF20).
150 nC * 13.56MHz = 2 ampere, which is on the order of magnitude of the output of the station!
Sergey mentions that the Metcal design does use such a transistor, but he used the TVS to allow for easier part selection.
The bigger concern is not when the transistor turns off, but when the load is disconnected, as we don't know when that is going to happen.
« Last Edit: March 11, 2021, 08:43:25 am by rfmerrill »
Offline parasole
  • Country: md
« Reply #552 on: March 11, 2021, 08:39:27 am »
Using 3x more current rating transistor sure would require more input power as usually gate input capacitance will increase, but my point was about possible improvement based on what I read about problems with that design.
yes, as I mentioned, using TVS for this frequency is ok, and it is not a linear amp that would have totally different requirements to its output. But in mamalala design used transistor is quite at the low end with its 100V drain voltage...
The bigger concern is not when the transistor turns off, but when the output is disconnected, as we don't know when that is going to happen.
Right, in this case, the whole power would be reflected, but for this, we have a feedback loop controlling DC supply... however I admit it might not be that quick, and combined with low-grade transistor the result is as is...
« Last Edit: March 11, 2021, 08:45:23 am by parasole »
Offline rfmerrill
« Reply #553 on: March 11, 2021, 08:43:40 am »
Respecting one of the PDFs you linked:  Going by their gate voltage graph they have something that looks vaguely like a ~12V amplitude sinusoid on the gate. With the gate capacitance of 2.6nF, that means the current waveform in and out of the gate is 1.6A RMS, so that's roughly 20 VA of reactive power just to drive the transistor. Doable of course but has to be kept in mind.
Offline rfmerrill
« Reply #554 on: March 11, 2021, 08:52:50 am »
I'm not sure what voltage the transistor in the mamalala design sees as it's not connected the same way as in Sergey's design. Sergey's design is basically class C. Mamalala's design might also be class C (could be A?) but it's transformer-coupled, so I don't know if reflected power hits the drain of the transistor the same way. (I'm an RF noob)
Offline parasole
  • Country: md
« Reply #555 on: March 11, 2021, 08:55:37 am »
That is one more point for pre-amp use, final stage gain is not that much and usually require substantial power to drive them...
it also looks to be class C as no bias network, and it is 1:1 transformer, then final amplitude depends on how well the output network is matched...
« Last Edit: March 11, 2021, 09:06:31 am by parasole »
Offline quadtech
  • Country: in
« Reply #556 on: March 11, 2021, 09:43:02 am »
Ocela over at vrtp.ru successfully transplanted the RF feedback from Sergey's design into the
Mamalala board (can see via google translate) -
https://vrtp.ru/index.php?showtopic=30618&st=300
Mamalala reviewed some of his design choices and scope for improvement here, including converting
from a single driver to a push pull design -
https://www.eevblog.com/forum/projects/diy-metcal-13-56-mhz-rf-supply/msg1467251/#msg1467251
Offline parasole
  • Country: md
« Reply #557 on: March 11, 2021, 10:16:08 am »
Implementing RF feedback is a must, good to see it is already done.
Regarding push-pull design, that is the easiest way, and I found one good "paper"  :D
Just use your transistor of choice and downsize the output transformer, just pay attention as it is transmission line type thus wound with coax cable...
Offline quadtech
  • Country: in
« Reply #558 on: March 11, 2021, 12:19:51 pm »
This one below looks good - for the output filter, the 20m band values in the first link are quite close -
http://pa-11019.blogspot.com/2016/11/diy-kits-70w-ssb-linear-hf-power.html
http://wa5bdu.blogspot.com/2019/03/70-w-ebay-mosfet-hf-amplifier.html
Offline parasole
  • Country: md
« Reply #559 on: March 11, 2021, 12:30:08 pm »
Yes, you may use the same ferrites and overall amp, it is wideband and will work happily on 13,56 Mhz.
One aspect to consider, they are linear and that affects efficiency, in solder station use we don't care about linearity hence bias network should be excluded which will transform it in class D amp.
Offline t0m
« Reply #560 on: March 13, 2021, 06:43:32 am »
If you want to try hacking a buck converter module to add feedback, maybe start with this. Based around LM25116, less than $10. https://www.aliexpress.com/item/32845237362.html
Offline parasole
  • Country: md
« Reply #561 on: March 14, 2021, 07:28:02 am »
I am considering using a buck-boost converter and being less dependent on the power supply side. Anyway, right now my focus is on RF power amp, now study some papers so to understand what could be done to remain on the cheap side and with better efficiency and more power...
Regarding LM25116, it looks to be no different from any other converters as feedback pin is available, do I miss something over here?
« Last Edit: March 14, 2021, 07:39:12 am by parasole »
Offline t0m
« Reply #562 on: March 15, 2021, 12:06:47 am »
The chip I think would be suitable, I'm just not sure if the feedback pin is easy to access on the module that I linked to.
Offline parasole
  • Country: md
« Reply #563 on: March 15, 2021, 01:01:29 am »
Doesn't look to be a problem, there is a picture from the bottom side and it could be seen that chip is fully accessible, and it should be relatively easy to solder a wire to feedback network resistors.
« Last Edit: March 15, 2021, 01:03:22 am by parasole »
Offline quadtech
  • Country: in
« Reply #564 on: March 18, 2021, 02:14:35 pm »
The Mamalala RF board provides VR and VF outputs for the Reverse and Forward power.
An LM3914 based SWR display can be used if someone wants to run standalone (no CPU board)
http://m1kta-qrp.blogspot.com/2009/11/lm3914-and-swr-and-protection.html
https://www.qsl.net/lw7daa/LM3914LED.pdf
Offline Serdg
  • Country: ru
« Reply #565 on: March 27, 2021, 05:28:20 am »
Can anyone give me a link for a soldering iron connector?
 Or his model. For example on ebay.
« Last Edit: March 27, 2021, 02:26:47 pm by Serdg »
Offline rfmerrill
« Reply #566 on: March 27, 2021, 08:26:53 pm »
If you mean the connector that the metcal handpiece connects to, it's just a normal type F coax connector.
I have tried a few different ones and I think this one works the best: https://www.digikey.com/en/products/detail/cinch-connectivity-solutions-vitelec/VF320/4430389
In general I would look for bulkhead connectors that are designed for the nut to go on the outside (as otherwise you have to disconnect it to remove it from the housing).
You also probably want one that has good length on it so it's easier to be sure the handpiece connector is fully seated. Note: It took me a while to learn how to best connect the handpiece connector, as it's kind of weird: You want to unscrew the collar on the connector all the way, then push it down over the jack as far as it will go, then spin the collar down and tighten it by turning the collar clockwise and the *cable* counterclockwise. You are not screwing onto the jack.
At first I tried connectors that crimp onto coax directly, but in my project there is not a lot of space for the cable to come in from the side of the housing, so I switched to using the above kind of connector and having the coax meet it at an angle.
Note that these soldering iron designs appear to all be 50 ohm *except* for the F connector, and most F connectors designed to go on a cable will go on 75 ohm cable!
Offline Serdg
  • Country: ru
« Reply #567 on: March 28, 2021, 04:56:25 am »
Thanks! Good connector.
The fixing nut in the body is probably more correct. Maybe I'm wrong.
Offline quadtech
  • Country: in
« Reply #568 on: March 28, 2021, 10:34:03 am »
These are the instructions which are bundled with a Metcal handpiece -
« Last Edit: March 28, 2021, 10:35:39 am by quadtech »
The following users thanked this post: Serdg
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
« Reply #569 on: March 28, 2021, 12:35:42 pm »
The blow-up at switch off can be fixed with a trivial circuit mod that disables the device if the input voltage is low. I added very crude circuit with Zener-based thresholding to mine which acted on the tip detect line to force a disable. Other more elegant ways are possible.
Yes, going to more power requires either a change of topology, probably to push-pull, or a larger transistor which then needs more gate drive. If I were to play with it I'd probably start by paralleling a second gate driver IC as the minimum-effort solution (the gate driver after all is a kind of preamp), but ultimately resonant matching of the gate drive would be better as the gate is really a reactive load and driving it with a resistive gate driver wastes a fair amount of power.
That looks interesting.  :)
Offline Serdg
  • Country: ru
« Reply #570 on: March 28, 2021, 02:20:19 pm »
    Great swivel connector! Very similar to the connector from an oscilloscope.
But where is the analogue of this connector sold?
« Last Edit: March 28, 2021, 03:45:57 pm by Serdg »
Offline rfmerrill
« Reply #571 on: March 28, 2021, 07:43:06 pm »
Ah, right, it comes with instructions  |O
The main thing I wanted to add (which is not in those instructions) is if you try to get it tighter by *just* turning the collar, you may end up loosening the jack (especially if you're using whatever F connector rather than the specific one Metcal chose). Turning the cable end the opposite way or holding it still makes sure your torque is applied in the right place.
Offline rfmerrill
« Reply #572 on: April 10, 2021, 04:18:24 pm »
I have one assembled and two blank boards, plus a little protoboard I made that generates the 12V and 5V, has an UVLO circuit and a bicolor LED that shows rf on/off.
quadtech hit me up for them first but they didn't answer a ping email--if anyone wants this stuff I can ship it for just a little over the cost of shipping.
Offline Splader
« Reply #573 on: August 06, 2021, 12:10:14 am »
Hello, I am rather new to all of this, I was hoping someone could point me in the right direction to actually build this. Im not sure on which design to go with, it looks to be that Sergey's is better but I don't know.
I need something that can push 80W and run off 120V mains as I have a Hakko FX-1001 that I plan to use with this. I'm not to great at designing my own circuits so it would be nice if someone could share Gerber's from they're build. Any information is highly appreciated.
Offline eevbstedt
« Reply #574 on: August 07, 2021, 05:16:26 pm »
On the downside, the range of tips that are available is very small.
It's very hard to find side by side comparison of the size of the handpieces. This makes me suspect that the 470K handpieces are significantly thicker, as the cartridges certainly are (going by the diameter of the cartridge compared to the tip).
I have and use a Metcal SP200 (470kHz unit) if anyone would like any info or details on it.
