Hi Paulo,
could you post an image from the assembled board viewed from top? Sharp (non-shaky) and having the board fill out all of the image area? Maybe i can see something then...
In any case, some pointers:
- You have used a trimpot for R25 instead of two equal SMD resistors. Make sure that you have half the 5V supply voltage at the center pin of that trimpot. It adjusts the offset of the OpAmp used for the control loop. If that is off too much you will not get the proper values.
- The dummy load just needs to be big enough to handle the output power, which can be way over 30 watts. A smaller dummy is OK if you only use it for short periods of time. If you want to test for long(er) periods, you need 50 watts or bigger. In any case, it must be a purely resisitve load. That means you can _not_ use things like wirewound resistors, since they are way too inductive.
- Verify that the supply voltages are all OK and stable. Check the main supply and see if it keeps up under load.
- Are you sure that you have 5.6 volts at L2? In the scope screenshot there is 60 volts peak-peak, unlikely to reach that with only 5.6 volts supply into the RF output transformer. At least not when there is a proper 50 ohms dummy load connected to the RF output.
- Check the RF signal at the junctions between L3/L4 and L4/L5. The concept of the regulation is to keep the RF voltage at the junction of L4/L5 more or less constant. A mismatch at the output will cause more RF energy to be reflected back, increasing the level there. Which in turn will cause the buck regulator to decrease it's output voltage. A matched load will cause a drop at L4/L5, causing the buck to increase it's output voltage. If you see a much higher voltage between L4/L5 than what you have at the output, then something is wrong with the load.
- Have you done the inital adjustment of R32 properly? It sets the maximum possible DC output from the buck regulator.
- Also make sure that no external signal is connected to the VLIM input (pin 3 on SV1). Applying a voltage there will cause the buck regulator to decrease the output voltage. Pin 5 is next to it and has the +5V rail, so make sure that there is no short or something.
In any case, as said, please upload a clear hi-res image of the board, so i can check things out and compare to what i have here. After all, there is always the chance that i made a mistake in the docu or such.
Greetings,
Chris
