Thanks
ajb for mentioning lots of important points. I’ll continue then with
cats herding and we’ll see if there is any chance to do that (possibly during the process we realized that no cats are in question
The electromechanical part of the specification can be seen as a lowest common denominator. I’m aware that many of us have different opinions, favors based on direct experience or simply belief. That’s fine and please take into account that what follows is just
another suggestion and if we’d like to push this topic forward a proposal that is favored by majority of participant should have an advantage. Proposal that follows take into account the following facts:
- DIY/maker community is very diverse and that diversity is caused by many factors like people’s age, available spare time, finance, venue/legal requirements, knowledge level, etc.
- Bus means connectivity between two or more units, but that’s also possible that particular unit is deployed as standalone. When more units exists they can share the same housing (“mainframe”) or can be housed in more shared or standalone/single unit housing.
- Digital control could be centralized, present on each module/unit or mixed
- Specialized instrumentation bus and interfaces, already exists on the market.
”Mainframe”/chassis with backplaneSpecialized instrumentation bus like
VXI already exists and we can learn from it that is possible to pack any type of instruments on the card/module and that many modules can co-exist in the same mainframe. I believe that mainframe concept offers electrical, mechanical, thermal (assisted with forced air cooling) capability that can easily fulfill DIY needs. Also it’s space-saver, that many can found important.
Modules can be fixed/connected inside mainframe only mechanically when additionally wiring has to be provided to establish communication. Another solution is to introduce backplane, a series of connectors that improve mechanical strength and provide electrical connection. I think that backplane is way to go. Since this is a DIY, backplane shouldn’t need more then 2-layer PCB what also put some requirement to connectors that we can use.
The mainframe itself should be as simple as possible that one can make it using simple profiles (L and/or rectangle) and metal plates that can be easily cut to size. The max. width of such mainframe shouldn't be wider then 19". If we selected VXI’s 30.5 mm (1.2") as a width of single module we could go with up to 13 modules. Of course, if necessary, modules could be wider in increments of 30.5 mm (i.e. 61, 91.5 mm, etc.) and can use multiple connectors for mechanical strength and more control lines.
Now we comes to more trickier part that is modules height and insertion direction. I found visually very attractive height of 2U. It looks very compact. But most standards is based on 3U height. Module height is directly connected with “insertion” direction/orientation. Think about PC slots: insertion direction is
vertical since a backplane, that is PC motherboard, is mounted horizontally. Thanks to that you can insert PC cards of various height and length as far as you do not exceed set limits. Actually you can mix and match various cards on the same PC. As far as I know this is not a case with industrial rack systems where backplane is mounted
horizontally on the rear panel that is vertical. They are started with 3U height, and could be 6U and even 9U and length (depth) could vary but it's not possible to mix modules of different length because all of them has to be fixed on front side.
Note: please correct me if mentioned directions are misleading and has to be swapped.So, if we choose vertical insertion we have more freedom to create boards with different height. Even if we don't have agreement about standard height (i.e. 2U or 3U) one can still make "low-profile" cards and insert it in mainframe that is set to 3U – you just need to mount it with 3U front panel.
Insertion orientation also set limits for bus connector(s). If horizontal backplane is selected then we have more room to positioning one or more connectors. I made one drawing in Eagle (you can also find .dxf export in attachment) to illustrate how that can be if horizontal backplane is used.
Main "disadvantage" is that you can not easily stack more boxes. But for DIYers that shouldn't be a problem. There is few of them who have a rack full of equipment (and indeed packed with "cooling fan sections" which noise could be unbearable
Talking about cooling with horizontal backplane we have complete rear side available for cooling fans. That is not a case with vertical backplanes. You have to add an extra 1U on top or bottom of the mainframe. Therefore min. height became 4U (very bulky if you asked me)!
Module's front panels are fixed with L or rectangle profile on bottom plate that also carry backplane, and with other screw is fixed to L or rectangle profile that is mounted on top cover plate. Therefore if you'd like to remove any of modules you have to remove top plate first. Looks unpractical on first, but you don't need to have top plate during testing phase and when everything is completed you can fix it with screws to the rest of the mainframe.
Backplane connector(s)Electrically we can work with two cheap and reliable connectors such like DIN 41612 Type 2C: female 09232486824 (backplane side) and male 09231486921 (PCB side). Three type of signaling should be available:
- Power is used for input and, if necessary, output power distribution. Some lines has to share multiple pins to allows total current of min. 5 A. That high current lines could be used to couple power outputs internally. As input power we can define "DC bus" like +48 Vdc and each module could derive all bias supplies from that voltage. Additionally we can specify voltage levels that can be much easier adopt to particular module power requirements, e.g. 3.3 V, +/-5 V, +/-15 V, etc.
- Analog is mainly small signal lines that can be used for internal wiring of signals that is not digitized because it's not critical or it's too fast/expensive for digitizing.
- Digital should be collection of various chip selects, triggering, sync/clocks and similar signals. I think that digital buses should be solely serial: multiple UART, I2C, SPI and CAN.
One "slot" (module position) should have special purpose: it has to be dedicated to CPU module. When full 19" wide backplane is used it should be placed in the middle. On shorter backplane (half or even quarter of 19") it can be located on one end.
Logically and electrically we should define mandatory (MAIN) and auxiliary (AUX) bus and try to be smart while allocating different functions to both of them. We can borrow some ideas from specifications such as VXI.
I’m aware the mandatory/auxiliary concept is an open call for trouble and incompatibility. Maybe it’s better to put that another way:
BASIC and e.g.
FAST/LEVEL2/ENHANCED. In that way two different type of modules should co-exist within the same mainframe with quite different power and signaling needs. For example simple instruments such as power supply or electronic load will use power and basic signaling of BASIC connector while digital oscilloscope will use fast signaling, triggering that is offered on the FAST connector.
Also on the BASIC connector we can define simpler way of communicate between Slot #0 (CPU module) and rest of the mainframe. I think that
void_error could offer here an appealing proposal that use minimum number of control lines. That in the first place could lower pins requirements on the MCU side.
"Out of box" communication or communication with outside worldCommunication outside mainframe/chassis can exists on different level:
- DIB chassis to DIB chassis,
- DIB chassis to DIB module,
- DIB chassis to propiatery/closed instrument(s) and
- DIB module to DIB module
Case #1
Pro’s: Your “lab” can grow beyond limitation of single chassis. Also if smaller/shorter backplane is initially selected and housed, you can continue to grow without throwing anything away.
Con’s: We need to specify inter-chassis communication, and define where connection point has to be located. I presume that should be the CPU module. Good candidates on lower layer are what you already proposed: Ethernet and serial (MAC, RS-485). I think that bridges such as USB-to-SPI could be a good and cheap candidate.
Case #2
Pro’s: Some modules especially complex and/or sensitive one could be detached from the rest of the system.
Con’s: Higher level of complexity, require own power supply, MCU and additional resources such as “local console” (i.e. LCD display, TFT display, encoders/keypads, etc.)
Case #3
Pro’s: Communication with legacy instruments can be established. A good candidate for interface are GPIB/IEEE-488 and serial (RS-232 or RS-485), but also Ethernet and USB for newer models.
Con’s: Additional complexity/cost related to GPIB (not a case for other interfaces)
Case #4
This is to my understanding that some of you already proposed.
Pro’s: High level of independence,
Con’s: See case #2
