Author Topic: Need IC that pulses every few seconds  (Read 3849 times)
Offline seeigecannonTopic starter
« on: August 01, 2016, 02:46:23 pm »
I am working on a battery operated device, and I want it to be able to last as long as possible. I am putting the MCU into idle, but it is still taking way more power than I would want it to. I would love to be able to put it into full-fledged sleep mode, but it cant wake itself up again without an external interrupt.
Is there an IC I can use that pulses once a second or once every few seconds, but doesn't need many external components and takes very little power? I would like to use that to trigger an interrupt. Thanks.
Offline MosherIV
Re: Need IC that pulses every few seconds
« Reply #1 on: August 01, 2016, 02:51:26 pm »
Erm, you want to be using a timer peripheral built in the microcontroller, they can generate a regular timed interrupt.
Alternatively, I would suggest the good old 555 timer, try a CMOS variant for extra low power.
Online Marco
Offline StillTrying
  • Country: Broken Britain
« Reply #3 on: August 01, 2016, 03:10:13 pm »
Its watchdog timer.
Or an RC on one of it's pins that charges or discharges when it's asleep.
Online Ian.M
« Reply #4 on: August 01, 2016, 03:25:17 pm »
Which MCU?
Offline Fungus
« Reply #5 on: August 01, 2016, 03:58:06 pm »
An Atmel ATtiny85 will do it.
I've made things that run on a Tiny85 for years using a single coin cell. They wake up every now and again and do something. Making a pulse every few seconds would be easy.
Edit: And so will an Atmel Mega328 - all Atmel AVR chips can sleep on microamps and wake themselves up periodically. I only mentioned the Tiny85 because they're small and I've built lots of coin-cell devices with them.
« Last Edit: August 01, 2016, 04:18:57 pm by Fungus »
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #6 on: August 01, 2016, 04:08:44 pm »
Linear TimerBlox if 3$ and 300(800)nA fine for you :)
« Reply #7 on: August 01, 2016, 05:38:59 pm »
Thanks for the replies. I am using an internal timer right now, but when I go into the full-on power savings mode the timer gets shut off and requires an external interrupt to get things kicked off again.
I am using a stripped down Arduino Pro Mini, so an ATMEGA328 MCU. I unsoldered the LEDs and removed the regulator and am running it strait off a 3.6V battery.
I did consider a 555, but I was worried about current draw, I can look into how low I can get it though. I am also worried about anything with a moderate component count as I am gluing all of the components to the bottom of the Arduino board dead-bug style.
Online JPortici
« Reply #8 on: August 01, 2016, 05:39:29 pm »
Read the datasheet of your MCU.
The power saving chapter.
Unless you are using a 20 years old pic or something you will have a number of options to get the cpu out of sleep by timers and/or interrupts.
And if you are using a 20 years old pic or something all those options will reset the mcu or trigger the interrupt so you just need to set a register/bit to chech whenever a reset or interrupt was fired by exiting from sleep, so your program act accordingly
Offline hans
« Reply #9 on: August 01, 2016, 05:44:27 pm »
You can use the watchdog timer to wake up the chip periodically. See page 39 of datasheet.
On some newer devices you may also have a RTC or RTCC that can wake up the chip for a given amount of ticks, or at a specific time/date.
There is absolutely no need to use an external timer chip for this.
I'd suggest looking around in some of the IoT libraries for their sleep/power management functions, or write your own with the datasheet on the power management/watchdog pages in hand. I believe JeeNode had a wonderfully simple to use sleepy function that slept the micro for an approximate amount of ms.
The following users thanked this post: seeigecannon
« Reply #10 on: August 01, 2016, 05:53:44 pm »
Thanks. Found a tutorial here http://donalmorrissey.blogspot.com/2010/04/sleeping-arduino-part-5-wake-up-via.html that looks like it will do everything I could want. No more external parts for me.
« Reply #11 on: August 01, 2016, 10:24:13 pm »
You guys are awesome. I was shooting for about a year of battery life and a quick calculation says that I should have about 5. All this with no external hardware. Thanks.
