Author Topic: Do you verify the netlist before PCB layout?  (Read 18912 times)
Offline c4757p
  • adieu
Re: Do you verify the netlist before PCB layout?
« Reply #25 on: February 06, 2014, 04:07:59 pm »
Then it seemed to be implied that I had pirated software and I took offense
I was just confused... I'd expect that if it knew it was pirated it'd do something a bit more effective than screwing with your ERC defaults...
Offline Bassman59
  • Yes, I do this for a living
« Reply #26 on: February 06, 2014, 09:43:36 pm »
bingo. hidden pins should be made illegal and fined !
Hidden power pins with implied and non-obvious net names? Take them out to the desert, give them a shovel, and tell them to dig a hole.
Offline free_electron
    • SiliconValleyGarage
« Reply #27 on: February 06, 2014, 09:54:26 pm »
who implied that. All i said is that , the pirated versions have all the DRc's disabled' That was a JOKE
Offline AlfBaz
« Reply #28 on: February 06, 2014, 10:59:21 pm »
Sorry free, I'm a bit touchy at the moment and its sometimes hard to pick up sarcasm from text  :palm:
Offline AlfBaz
« Reply #29 on: February 06, 2014, 11:07:27 pm »
I remember when I first come across this in protel for some of their parts in the supplied libs. It made a "little" sense as back in the day you mostly only needed Vcc @ 5V. I still didn't like it but if you selected "Show hidden pins", their placement was horrendous
