Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
DIY Dispenser Needle Bottle Stoppers
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: DIY Dispenser Needle Bottle Stoppers (Read 2068 times)
robrenz
Super Contributor
Country:
Real Machinist, Wannabe EE
on:
February 06, 2014, 09:36:57 pm »
In my
DIY flux bottle thread
I used a piece of O-ring to cap the dispenser needle. Turns out that does not work well for long term storage. The flux can dry out in the tip and it wont dispense. So the fix is making a music wire stopper that is one or two mills smaller than the dispenser tube ID. The length should be long enough to go thru the entire nozzle and sanding a nice taper on the end makes it easier to get into the tube. The loop makes it easier to grab and to see when its out of the bottle. Works to slow evaporation of solvents like the Methanol bottle shown. The flux needles are 24 ga which are .015" ID with a .012" music wire. The solvent bottle is 26 ga which is .011" ID with a .010" music wire.
Last Edit: February 06, 2014, 09:39:49 pm by robrenz
Logged
My video channel
https://www.youtube.com/playlist?list=PLRe7NGdsY7s6sOTsRahdb_sx2oDwGbh_O
jeremy
Super Contributor
Country:
Re: DIY Dispenser Needle Bottle Stoppers
Reply #1 on:
February 06, 2014, 09:50:23 pm »
Great! I've also seen this done with wax on the handle part to prevent it cutting your fingers when you pull hard
Logged
mcinque
Supporter
Country:
I know that I know nothing
Reply #2 on:
February 06, 2014, 10:46:21 pm »
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
