Author Topic: Isolation Transformer and Variac Safety  (Read 2739 times)
Offline BryanTopic starter
« on: January 02, 2016, 09:36:03 pm »
Good video on some pitfalls of newer isolation transformers. Seems the newer types are geared for medical use, not repair use. This video explains it better than a few others I have seen.
https://youtu.be/XBsQ3sZ45Fk
« Last Edit: January 02, 2016, 10:14:16 pm by Bryan »
-=Bryan=-
The following users thanked this post: Electro Detective
Offline nctnico
Re: Isolation Transformer and Variac Safety
« Reply #1 on: January 02, 2016, 11:03:26 pm »
Test bench safety and isolation transformers don't go together so skip that video!
Offline Ian.M
« Reply #2 on: January 03, 2016, 08:23:45 am »
Lousy video.
Takes 6 minutes of waffling to fail to explain why you don't want the isolated outlet to have any earth connection, then starts discussing the pitfalls of trying to 'float' a scope with it. At 8:30 he lights a bulb between mains Live and the scope probe ground clip, proving that he doesn't care enough for his own safety to have a RCD (ELCB) on his bench supply circuit.  He then manages to float his scope at 11:45 using an old USA 2pin socket to 3 pin plug adapter with a flying ground wire going nowhere, and proceeds to make his whole scope live on a bench filled with other presumably earthed test equipment via the scope probe ground clip, while holding it.
In any workplace I've been in, he'd be on administrative leave while the company safety officer reviews his persistent failure to follow safe working practices.
« Last Edit: September 22, 2016, 08:38:34 am by Ian.M »
