Well, I'm building a reflow oven controller. Another in the long line of hobbyists building controllers.
I'm currently using a TechFX (now defunct) Reflow2 controller for my 2600W/230V convection toaster oven. It works OK when it decides it wants to talk to the PC. So I figured I'd roll my own to deal with a few issues I don't like about the TechFX. Not the least of which is the horrific overshoot. Primarily it's an opportunity for me to dig into several microcontroller aspects all in one project.
The controller will be an Atmel ATMega644P/324P @16MHz (644P for development right now)
The LCD will be the SparkFun 128x64LCD (No serial backpack). I've used upgraded firmware for SparkFun's own serial backpack to drive the screen directly from the 644 (text, lines, etc all works very nicely now).
PWM control of the backlight(possibly).
PWM control of Heaters and cooling fan via SSR (0.5-1.0 HZ, maybe with min on-off, PFM to not switch the SSR too quickly at high or low duty cycles)
On/Off control of the oven's convection fan.
A MAX7315 8 port I2C I/O expander with PWM and an interrupt pin (indicator LEDs, buttons, etc)
At least 2 MAX81355 Thermocouple cold-junction to SPI chips. (It's the 6675 successor, with error flags, etc)
A rotary encoder for changing settings, etc.
EEPROM storage of temperature profiles, maybe and FTDI-USB connection.
Also going to have the temperature display as a rolling graph while running a profile.
Soooo? What do you guys think? Any feedback? Gotcha's? good ideas for a UI?
