Author Topic: DIY Articulated Magnetic Camera mount  (Read 17012 times)
Offline robrenzTopic starter
  • Real Machinist, Wannabe EE
« on: September 06, 2013, 10:52:09 am »
Following Daves "EEVblog#493 DIY Video Camera Dolly For Workbenches" thread finally made me get off my but and design and build what I thought would be the Ideal camera mount system for use in my shop. I had been constantly frustrated with not being able to quickly and easily get the camera where It needed to be.  It took a while because that pesky "real" work keeps getting in the way of my fun work.  There are things that I would improve on future versions but I am pretty happy with how this first attempt turned out.
Offline GeoffS
Re: DIY Articulated Magnetic Camera mount
« Reply #1 on: September 06, 2013, 11:24:37 am »
Excellent stuff!  :-+
Love the video, lots of ideas to use for my next metalworking project.
Offline ablacon64
  • Country: br
« Reply #2 on: September 06, 2013, 11:25:38 am »
Very good! Thanks for the video!
Offline EEVblog
« Reply #3 on: September 06, 2013, 11:56:02 am »
Awesome  :-+
Offline dr.diesel
« Reply #4 on: September 06, 2013, 12:05:10 pm »
Rob, most excellent!   :-+   If you ever decide to make a few of these, count me in!
Offline IanJ
  • Country: scotland
  • Full time EE & Youtuber
    • IanJohnston.com
« Reply #5 on: September 06, 2013, 01:34:18 pm »
Me too.......I'll have one.....cash waiting.
Ian.
Ian Johnston - Original designer of the PDVS2mini || Author of the free WinGPIB app.
Website - www.ianjohnston.com
YT Channel (electronics repairs & projects): www.youtube.com/user/IanScottJohnston, Twitter (X): https://twitter.com/IanSJohnston
Offline firewalker
  • Country: gr
« Reply #6 on: September 06, 2013, 02:10:07 pm »
Any reason for using silver ans not brass?
Alexander.
« Reply #7 on: September 06, 2013, 02:14:06 pm »
Alexander.
Lower temperature and better flow than brass. I use 56% silver solder for lots of other things so it is just what I have on hand.
Brass (brazing) would work also.
Offline firewalker
  • Country: gr
« Reply #8 on: September 06, 2013, 02:45:06 pm »
I forgot the most important: Excellent job!
I really like watching video like yours (machining). One of my favorite yt channels is myfordboy.
https://www.youtube.com/channel/UCNC9gjgYrzLfyMQmp31DnjA
Alexander.
Offline BillyD
  • Country: ie
« Reply #9 on: September 06, 2013, 03:59:12 pm »
Absolutely brilliant piece of work.
Offline DarkPrince
« Reply #10 on: September 06, 2013, 04:37:46 pm »
Awesome! Enjoyed the walk-through of the making too. Thanks.
Offline jaxbird
« Reply #11 on: September 06, 2013, 04:52:51 pm »
Awesome work  :-+
Analog Discovery Projects: http://www.thestuffmade.com
Youtube random project videos: https://www.youtube.com/user/TheStuffMade
« Reply #12 on: September 06, 2013, 04:59:16 pm »
Thanks to everyone for the kind comments.  I am trying to find the level of construction detail coverage that more viewers will enjoy.  There are not many who enjoy my longer videos that cover every detail of making things. :'(
Offline sync
« Reply #13 on: September 06, 2013, 05:31:19 pm »
I really like your videos which shows the making. I learned machinist at school. But never work as one. I find the kelvin probe videos very fascinating. Working at such tiny dimensions is impressive.
Using a magnetic base is a real machinist solution. :-+ I really like it!
« Last Edit: September 06, 2013, 05:33:12 pm by sync »
Offline quarks
« Reply #14 on: September 06, 2013, 07:16:47 pm »
Thanks a lot for sharing your great work!!!
If you are not already interested in professional foto/film accesory,  you should really begin to look into it. Because with your fantastic skills you are able to compete with premium brands like ReallyRightStuff, Kirk, Gitzo and others I have stuff from.
« Last Edit: September 06, 2013, 07:21:16 pm by quarks »
Offline JackOfVA
« Reply #15 on: September 06, 2013, 10:14:13 pm »
Nicely done indeed, both in the design and execution.
A couple questions as an EE who had to learn a bit of machining to build my projects.
1) I have been under the impression that lapping compound and the like should be kept far away from the lathe and mill and other precision tools as you don't want specks of the lapping grit to wind up in places where it shouldn't. That didn't seem to bother you much. I keep my bench grinder, for instance, 30 feet or so from the lathe and mill. What's the real story?
2) Over time, will the ball-to-carbon fiber surface become work polished and hence not develop enough friction to hold the arms in place? Or is that expected and the solution is to tighten the plates to increase pressure between the plates and ball surface?
« Reply #16 on: September 07, 2013, 12:41:09 am »
Thanks, I think of you every time I look at those 2 new bipolar power supplies I got because of your post :-+
1.  Generally good advice but IMO it really depends on how your equipment is protected. If you notice my lathe has neoprene sheet covering all the ways and slides so no grit is falling on sliding surfaces. I also have paper towels down to get the worst of it. The chuck jaws were removed and washed in the ultrasonic cleaner and the chuck scroll and slots were completely cleaned and re-lubed. Then all the covers were wiped clean to get any stray grit off. So I take a lot of care to make sure the damaging effects of abrasives don't get a chance to destroy my toolmakers dream ;D (that is the industry nick name for the Hardinge HLVH tool room lathe)
2.  I expect that will occur to some degree over time. The 2 bolts apply the preload have nylock nuts so tweaking the drag force later on will not be a problem.
Offline JackOfVA
« Reply #17 on: September 07, 2013, 12:55:54 am »
Thanks - makes sense.  I suppose if the ball joints were exercised 24/7 some sort of replaceable friction material could be used, like a brake pad.
I have a friend with a Hardinge toolroom lathe - he spent over a year restoring it to the point where it looks and works like it was just delivered from the Hardinge factory.  I have a long bed, gearbox Myford here.
Offline notsob
« Reply #18 on: September 07, 2013, 03:16:31 am »
your workshop is still on my xmas list
« Reply #19 on: September 07, 2013, 04:16:08 am »
I did not research what was available before I made this but your post prompted me to look. You are right, I could find nothing of this size/range of motion.  Maybe I should try a Kickstarter project to see if there is enough interest.
alm
  • Guest
« Reply #20 on: September 07, 2013, 04:39:27 am »
Wouldn't costs be prohibitive if you factor in labor and the fact that you might get hundreds of orders?
« Reply #21 on: September 07, 2013, 05:59:35 am »
Can be cost reduced at the expense of increased mass. You can have aluminium hollow balls made and machined round, with the threaded mounting built in. Then use a threaded rod for the tension member. The rest is easy to have CNC made, though you would probably just have them tumbled to do the edge finish. Other than that it is a very good design, very stable and a lot better than any others out there.
Offline BravoV
  • +++ ATH1
« Reply #22 on: September 07, 2013, 09:11:59 am »
Robrenz, just ruined my keyboard again from uncontrollably drooling after seeing those metal working tools, and of course your skill.  :'(
Great video, learned tons from there, thank you !  :clap:
PS : Where are those recently acquired two HP precision lab psus ? Can't see them in your shelf there.
« Reply #23 on: September 07, 2013, 11:37:03 am »
This was a first pass "breadboard" design using mostly junk box components/materials. I would do a complete redesign for even better functionality and a thorough DFMA analysis before I even showed it on Kickstarter.  It would be totally outsourced other than possibly assembly/shipping depending on # of units.
« Reply #24 on: September 07, 2013, 11:44:30 am »
I definitely think there is a market for it.
Interest level in this thread will give us a hint as to whether you are correct. :)
I think I covered your other points in my response to alm above.
@ SeanB  Yes and Thanks.
@ BravoV  Thanks,  they are on other shelves at the moment and the 6115A still needs a restore video
« Last Edit: September 07, 2013, 11:55:06 am by robrenz »
