Author Topic: Virtex 7 2000T board current estimate  (Read 280 times)
Offline nth_degreeTopic starter
« on: September 10, 2024, 04:09:17 am »
I have a PCB that takes 12V input and hosts 4x Virtex 7 2000T FPGAs as well as connectors for two FMC daughter boards. What do I need back of the envelope? Best recommendation for a compact regulated power supply for this job?
Online RoGeorge
Re: Virtex 7 2000T board current estimate
« Reply #1 on: September 10, 2024, 11:01:58 am »
Any desktop PC power supply should work.
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #2 on: September 10, 2024, 08:53:46 pm »
Power consumption of any FPGA (and Virtex 7 in particular) is VERY dependent of RTL, loaded into them. Blank chip can consume a 10-100mA (you can find out exact number in Datasheet), fully loaded can consume up to tens of Ampere (close to 100A, IMHO)
Online RoGeorge
« Reply #3 on: September 10, 2024, 09:28:13 pm »
The capsule of a Virtex is about the same size as a CPU, so probably no more than 50W.  Better estimation might be done by the size of the radiator, if there is any.
For the exact power for a given application, see this answer:  https://adaptivesupport.amd.com/s/question/0D52E00006iHvuDSAS/power-consumption-zynq-virtex7-and-ultrascale?language=en_US
« Last Edit: September 10, 2024, 09:29:58 pm by RoGeorge »
