Author Topic: DIY 18650 Lithium Battery Charge, Protect, Boost to 5V Circuit  (Read 976 times)
Offline dusnokiTopic starter
  • Country: cs
Hez guys, new video is finallz up. I created a DIY 18650 Lithium Battery Charge, Protect, Boost to 5V Circuit. It can charge the battery using a micro usb cable, protect it from overdischarge, and boost the voltage to 5v.
It wasn't easy as I'm a web developer by profession and only meddle in electronics on a hobby level, and have learned anything electronics related from youtube videos :D
I've read a lot of datasheets and used SMD components so the board would be the smallest possible. It isn't as small as I would like but for my first try it's not too bad. Main thing is that it works :)
You can check out the video at
I'll just leave you with a couple of pictures of the board and schematic.
Hope you like the video :)
