Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Display Project
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Display Project (Read 1244 times)
Dr.No
Newbie
Country:
Display Project
on:
September 17, 2016, 05:56:24 pm »
Hi!
I want to realize a project, that uses a RGB TFT Display but i am an Noob with programming=D
http://www.mouser.com/ds/2/291/NHD-5.0-800480TF-ATXI-231021.pdf
The Display uses a 24-Bit Parallell RGB Interface (Parallel 8800) and I want to controll it with a AVR MCU but now the big question: Which one??
In the End the Display just have to show a vertical and a horizontal line, so no advanced Video stuff...
Can anyone give me a tip, which MCU i could use (maby one with a developmentboard and some librarys for the interface available?)
greez
Logged
bktemp
Super Contributor
Country:
Re: Display Project
Reply #1 on:
September 17, 2016, 06:07:49 pm »
You can't drive the display directly using a AVR.
You need to add a display controller. S1D13748, S1D13517 or SSD196x work fine for such displays:
http://www.solomon-systech.com/en/product/display-system-solutions/display-controller/ssd1962/
http://vdc.epson.com/index.php?option=com_docman&task=cat_view&gid=68&Itemid=
Depending on how fast you want do redraw the screen a AVR might be a bit slow (800x480xRGB=1152000Bytes is a lot of data).
Logged
Dr.No
Newbie
Country:
Re: Display Project
Reply #2 on:
September 19, 2016, 07:13:16 am »
Yea! that helps a lot! Thank You
-> specially, because now i found out, that the Display Pinout nearly matches with the pinout, the controller calls "MCU Interface" !! MHMM! That means, there is allready a Display Driver in my Display! nice=D
Last Edit: September 19, 2016, 08:15:05 am by Dr.No
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Display Project
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
