Hi all,
for my discrete CPU idea which is simmering on low fire I still need a display and a CRT would fit perfectly (I even have an almost working scope clock design, so CRT control is done).
But how do you generate text on a CRT using discrete components only (not using VHDL/FPGA or a microcontroller, which would be the trivial option)?
Two designs from the relevant era (around 1965?) come to mind:
The CDC 6600 is a discrete supercomputer with vector CRT display. Schematic is in here
http://www.bitsavers.org/pdf/cdc/cyber/cyber_70/fieldEngr/60125000C_6602_6603_6622_6681_6682_Data_Channel_Diagrams_Dec65.pdf starting from page 5.
Not sure about the IBM System/360, which was also fully discrete.
And (probably more known on this part of the forum) there is the Tektronix 7000 series readout. It is described here
https://w140.com/tekwiki/wiki/7000_series_readout_systemwith the key component being an analog ROM (designed by Barry Gilbert), schematic
https://w140.com/tekwiki/images/d/d9/Tek_155-0023-00_155-0024-00_155-0025-00_155-0026-00_155-0027-00.pdfI find this quite elegant as it solves both the coordinate storage and the transition or vector generation - fully analog (the LeCroy orange CRT scopes used analog integrators for vector generation, but the rest was fully digital (68000 IIRC)).
Unfortunately I have neither a supercomputer design budget (or team) nor access to a foundry making full custom chip designs. What I do have (and Seymour Cray or Barry Gilbert didn't have) is the JLCPCB assembly service, which let's me order a PCBA with a few thousand SMT components without going bankrupt. Unfortunately chip design specials as for example Gilbert's multi emitter transistors (mask programmed) for the analog character ROMs are not easily replicated with discrete components (I'll give that a try though).
Any other idea how I could tackle character generation?
As a side note: Looking back, in these times (1960s) there seemed to be many "celebrity" designers - Shockley, Gilbert, Wilson, Cray, Widlar... If I would have to name a famous designer of the past few decades, I would not know a single one. Are there none or do I just not know them? Maybe today's technology has gotten that complex that no single genius could achieve something worth mentioning (thing of the monstrously complex EUV steppers)?
- Martin
