Hi guys,
First of all, thanks for the information. The reason for the pulse caps was that this should be quite fast - very low rise time ( <100ns preferable) and the actual on time should be around 2us, with a repetition rate of 500Hz - this gives a fairly low average power, but a large pulse power. As such parasitic inductances could cause problems. The best parameters I've seen were in various pulse caps.
The reason for the relatively high capacitance is that the voltage should drop as little as possible during the actual pulse.
But now that I think about it you are right, a bank made up of a series-parallel combination of good fast (but not too pulsy) caps should do the trick, assuming some charge balancing resistors are used.
Is there any cap you would recommend for this? I'll scour the obvious suspects (EPCOS, ES-OSTRAVA, AVX) tomorrow.
Thanks,
