Author Topic: Cleaning PCBs  (Read 25061 times)
alm
  • Guest
Re: Cleaning PCBs
« Reply #25 on: April 13, 2012, 07:36:08 pm »
Note that the permissible exposure limit for hexane is quite close to ethanol. Make sure to only drink beer in a fume hood with gloves and a respirator if you get exposed to it daily ;). As you state, it's not really much worse than many other common organic solvents. They're not harmless, but not worth worrying about for occasional hobbyist use.
Offline IanB
Re: Cleaning PCBs
« Reply #26 on: April 13, 2012, 08:18:45 pm »
I just think it's a bit strange to include hexane into a standard flux remover
Hexane would come under the general category of petroleum distillates, and solvents like these are a common constituent of "Goo Gone" and similar products. In other words, they tend to be really good at dissolving stuff...
Offline Wim_L
Re: Cleaning PCBs
« Reply #27 on: April 15, 2012, 07:26:59 pm »
Oh, absolutely, but heptane would fit in the same solvent category, and doesn't get metabolised to things that (with chronic exposure) damage the peripheral nervous system.
Offline poorchava
  • Troll Cave Electronics!
Re: Cleaning PCBs
« Reply #28 on: April 16, 2012, 02:56:16 pm »
I'm using either isopropyl or turpentine. The latter i use mainly when using flux-paste (which is designed for soldering extremely thick, heavy and oxidized stuff, works like a charm but leaves sticky, oily residue which won't come off with isopropyl). Turpentine you can but from paint shop. It has a downside of extremly strong odor of pine.
Offline IanB
Re: Cleaning PCBs
« Reply #29 on: April 16, 2012, 03:07:43 pm »
You could try turpentine substitute instead, perhaps? It is sometimes called white spirit or mineral spirit. It is generally clear and odourless.
Offline free_electron
    • SiliconValleyGarage
Re: Cleaning PCBs
« Reply #30 on: April 16, 2012, 04:51:11 pm »
terpentine is not a good idea ...
Offline T4P
  • Country: sg
    • T4P
Re: Cleaning PCBs
« Reply #31 on: April 16, 2012, 09:57:15 pm »
turpentine not the best idea , really .
I had turpentine damage the plastic cases of DIP/SOIC and my skin .
Offline Alex_arg
  • Country: ar
Re: Cleaning PCBs
« Reply #32 on: April 17, 2012, 11:13:39 pm »
Hi!, i use regular alcohol 96% to clean new and old resine an d flux from PCBs, the key to success here it's time, very volatile solvents like hexane or thinner evaporates before flux starts to dissolve, so you got to protect it from air, i do so by wetting a piece of cotton and applying it over the board and wait a while, old fluxes require more time.
In case a white layer still on the pcb (it's only the dissolved flux) , you must repeat the process with a new piece of cotton and voilá! . You could use a nylon brush in hard cases previous wetted with alcohol.
In other times i've used a contact cleaner from Philips, that do the same job in much less time, but i think they don't produce this spray anymore. The one i mention has a clear smell of turpentine.
Offline Ajahn Lambda
  • quecksilberdampfgleichrichter
Re: Cleaning PCBs
« Reply #33 on: April 18, 2012, 01:01:40 am »
Acetone is fairly safe to us humans, aside from its flammability.
But hoo boy, it will melt the shit out of any plastics in the area!  Even the vapors can make some plastics gooey.
Re: Cleaning PCBs
« Reply #34 on: April 18, 2012, 04:28:06 am »
Acetone is a non-no as it can attack the casings of components !
Use rubbing alcohol / isopropylalcohol or real flux remover. Nothing else !
