If 10k would be at switch side of 1k you will be driving IC input with true 0 and not 1/11 of VCC.
Then you could replace 1k with 100k and 47n with 470p to make both state changes with almost the same time constant.
I wish I could understand what you wrote.
I wanted to show you step by step these operations but I have never inserted a graphic at this forum and I see I don't know how to do it.
I have experience only with KiCad forum and there I simply drag-drop file on my post and done. Never had any problem with it.
Here.
Dragging picture at post - not works.
I opened under post "Attachments and other options" and sometimes when I used "Select file" it was added under this box and box all the time said "File not selected".
At the end I managed to have there three lines in each I have file specified (I got it there by "Select file" and "Show all files" and then clicking my file.
In each line I have selected "Inline full-size image" and at the end of my message I have commands attachimg one by one starting from 1 to 3 (and my files have names ending with 1..3 in the same order, but in preview I have as attachment 1 info that here is C:\fakepath\Piano_2.png, but Piano_2 was selected for second attachment and not for first and C:\fakepath is not existing at my PC. Then as attachment 2 the same way is my Piano_3.png listed and then when I would expect attachment 3 I see info "Specified attachment is not availabe" what can be supposed is related to my first attachment that should be before those two. All files were selected by me the same way. Seeing difference I have selected them all once more time step by step.
Let us see what will be really shown.
[ Specified attachment is not available ]
Editing after posting.
I'm surprised that my attachimg=2 and attachimg=3 are shown as first and second (even in preview I see C:\fakepath) and still don't know what is wrong with my attachimg =1 (that should be before them).
So first picture that was a copy of original is simply not visible but those two are two steps previously described by me in text. I wanted to write the right sentences between them but now I don't know which text would be shown where as someway forum software sorts my attachimg differently than I see them in my post text.
