Yes, you are right this is a 4Q design, I think the NGM202 is also like that, they just limited some functionality, like the negative rail is only -6V and I guess they limited the output in software to be 2Q.
Ampout is used to measure the current via the difference amplifier U1. Later, this will be the ground when I will use a separate floating supply for the output amplifier and in that way I can even go for higher voltage output.
The output amlifer is not so interesting after U5, it is a voltage and current booster, based on LT’s AN-18. I think you are right it is like an audio power amp. The magic happens in U5 which follows the voltage set to the non-inverting input, which is than amplified by the power stage. This is where force is going into, limit is implemented in software and adjusts the force not to exceed the limits. The inverting input gets the feedback either from voltage or current measurement.
On top on this simple analog part I’ll add an ADC to measure voltage and current and a DAC to set force voltage. The rest happens in software or maybe in an FPGA. Currently, the software is also pretty simple, but can be more complex, like adding filters (FIR for ADC, control the slope, etc.).
No, I did not consider thermal stability yet.
