Author Topic: DI 469 Transistor  (Read 1826 times)
Offline eddy66t6Topic starter
  • Country: ie
DI 469 Transistor
« on: April 15, 2016, 05:33:49 pm »
So I'm modding some music gear, and looking for anyone who has ever seen this transistor? It's a drum machine that I'm working on, the audio appears to enter the transistor and a trigger signal triggers the audio and transistor at the same time which goes off to a mixing section then on the P.C.B. I'm just looking for data to confirm my thoughts and suspicions; footprint or package type and possible replacement if needs be...
The writing says DI 469 R M on each of them (there's 8...). (I've already done the google on it...no joy)
Thanks
« Last Edit: April 15, 2016, 09:18:12 pm by eddy66t6 »
Offline 4cx10000
Re: DI 469 Transistor
« Reply #1 on: April 15, 2016, 05:41:35 pm »
Hi!
How about 2SD1469R  8)
  • Country: ie
« Reply #2 on: April 15, 2016, 07:34:20 pm »
Hi thanks! That looks exactly right thanks! Of course what I thought was an I was a 1  |O
I'd never seen the type of package before...
Offline Seekonk
« Reply #3 on: April 15, 2016, 08:48:49 pm »
Looks like an opamp.
  • Country: ie
« Reply #4 on: April 15, 2016, 09:16:14 pm »
That's pretty much what it appears to be....there's 8 channels of audio, each coming into it's own transistor here, with three resistors and a filter cap...each each channel has a different 'level' resistor... I've traced this section out this section and it appears to be a fixed mix for the Left and Right outputs of audio. There's some individual channel panning going on somewhere too...
