Signetics had a quadruple timer in its program: NE558. However, these are not four complete NE555. The DIL16 package would not be sufficient for four complete NE555.
All four timers share a voltage divider, which is used as a reference signal for the comparators. In the four timer blocks, the discharge transistor is connected directly to the comparator. The NE555 has a push-pull output stage. The NE558, on the other hand, only has a lowside transistor. There is also a NE559, which is equipped with a highside transistor at the output.
The edge length of the die is 2,4 mm. The four-part circuit is clearly recognizable. In contrast to the NE555 (
https://www.richis-lab.de/555_6.htm), each section contains only two of the distinctive power transistors.
The NE558 shown here was produced in 1993 and is therefore somewhat more up-to-date than the first variant.
This NE558 has a different design. The auxiliary structures, the designation and the mask revisions have changed. The bondpads have also been placed slightly differently.
With a datecode from 1994, this NE558 is the newest of the three modules.
It features the same updated design as the NE558 from 1993, which could be extracted more cleanly from the housing material.
https://www.richis-lab.de/555_40.htm
