Hello people.
https://www.eevblog.com/forum/buysellwanted/wtb-(eu)-ohm-converter-for-hp-3450a-b-multifunction-meter/In this url, i had looked after this card / good schematic (avaible scan is very terrible )
Ohm_converter_original_schematics.pdf (212.86 kB - downloaded 73 times.)
my notice by reserve engineerging (sorry, some is german)
sammelnotiz für Widerstandmessoptionen_07.07.2021.pdf (1696.13 kB - downloaded 78 times.)
finished schematic, no fault in digital side. analog side needs some improvement. (Improvement is finished, TL071 replaced by OPA132 and similar)
REV_A Schematic.pdf (132.06 kB - downloaded 57 times.)
It works (logic side ) well, only analog side hat a bit problem with high restiance range ( 1M and 10M), value is non linear. (~2% )
I have removed all 5 Diode on OP-amp. With Diode is result much worser.
Despite nonlinearity on higher range is stabilty well.
EDIT: 11:30 , problem with nonlinarity is solved: TL071 should replaced by OPA132 or similar with extremely low input current.
I make think about puplished of kicad project. I have four PCBs left, who want it. (donate and shipping cost from EU (germany))
[ Specified attachment is not available ]
After finished of pcb, your HP 3450A/B should be modified ( A4 pcb module, Ohm config wire should be cutted and place with capacitor )
