Are you using a 10mH (milli Henry) inductor for the buck converter? Anyway, even with the correct inductor you'll get ripple. To reduce the ripple I'd suggest to add a LC filter at the output, something like 10 or 22 µH and a low ESR cap with a few hundred µF. I can't tell you if the ripple will cause any trouble without any knowledge about the circuit. If you like to get some feedback please tell us about your circuit.
