Author Topic: Designing a HDMI capable Board with F1C100s Processor - Seeking Input  (Read 1317 times)
Offline ShadowNomadTopic starter
Hey there!
there are a variety of boards based on the F1C100s/F1C200s processor, and I am currently working on designing my own. The datasheet shows that the processor offers several display output options, including a Parallel RGB interface with resolutions up to 1280x720@60fps.
However, I don't plan to connect a display directly, but am considering integrating an alternate output. The F1C200s does offer a TV composite output that I could theoretically use, but so far I haven't seen anyone actually use this feature in their board design. Also, I'm unsure if Linux supports this output as a display, especially given Allwinner's lack of documentation. In addition, the quality of a composite signal is not comparable to a clear digital signal, and three jacks (2 for stereo audio and 1 for video + an amplifier circuit for the audio) takes up a lot of space on the board.
So I am considering integrating HDMI with an HDMI transmitter IC like the Sil9022. However, I wonder if this would actually work. A first look at the datasheet of the Sil9022 shows that it supports a 1280x720@60fps signal as input.
I2S audio is also supported by both ICs. However, the F1C100s is not very powerful and does not even have a GPU let alone an FPU. In addition, I'm also interested to know if any public schematics based on the Sil9022 exist, as I personally haven't found any.
I am aware that my board will probably not be any more compact than a Raspberry Pi Zero and will definitely offer fewer features (and thus be pretty useless). Still, the idea of having a chip output HDMI without a dedicated GPU fascinates me. I think it could be an exciting design challenge.
What are your thoughts on this? Can anyone help me with some information?
Many thanks in advance!
« Last Edit: September 28, 2023, 09:16:42 pm by ShadowNomad »
Offline DavidAlfa
Re: Designing a HDMI capable Board with F1C100s Processor - Seeking Input
« Reply #1 on: September 28, 2023, 02:11:49 pm »
« Reply #2 on: September 28, 2023, 07:47:08 pm »
The SSD210 is definitely interesting. However, I have already decided to go with the F1C200s chip in my current design and the SSD210 is also definitely harder to find online. For future projects though, I will keep an eye on the SSD210 as it is promising. Thanks for the tip!
Offline DavidAlfa
« Reply #3 on: September 28, 2023, 08:03:42 pm »
Well in that case leave composite signal as last resort,. composite quality is pretty bad.
You might be able to do something with the lcd output:
https://www.eevblog.com/forum/beginners/capturing-video-from-lcd-interface/msg5059381/#msg5059381
« Last Edit: September 28, 2023, 08:08:24 pm by DavidAlfa »
« Reply #4 on: September 28, 2023, 09:22:21 pm »
I have looked at the TFP410 IC you linked before and it seems to be much better documented than the Sil9022 (and a bit simpler overall). However, it doesn't support audio, which is different with the Sil9022 HDMI transmitter I was considering.
