Author Topic: Design help for "smart switching" battery charger for DIY speaker. BMS?  (Read 517 times)
Offline Bassblaster505Topic starter
Greetings, ive been working on and off on this big Bluetooth speaker that runs on a 12V 4.5Ah SLA battery (it was free and holds a perfect charge lol). The plan was to toss together and get rid of loads of parts i have laying around and put them to use. The unit runs off an older car head unit with Bluetooth that will power a pair of 4" woofers and Dayton Audio tweeters. Its RCA preout feeds a separate mono TPA3116D2 amplifier thats sole purpose in life is to feed a 2.5Ohm 8" subwoofer. Not gonna lie i basically ripped the design from the "Blast Box 200" that Parts Express sells.  Ive attached a block diagram of how the unit would be wired up, pay close attention to the power delivery section, as the 12V SLA will charge through a center negitive external charger that disables power to the rest of the unit when charging
That original design was over 2 years ago and today i would be interested in using a "smart" (i dont know the actual name) battery and charger setup. In a perfect world i would like to run a 4S2P 18650 pack and have ONE single DC jack that will power the unit, charge it and play from battery power on its own. I Look at big name Bluetooth speakers for inspiration, Such as my Harman Kardon Studio 5 but i dont know HOW those circuits work. Is it just a BMS? or is there more to it?
Sorry if made myself sound like a complete newbie, I've been into audio and analog circuits all my life, but ive never been big on battery power or its charging setups
Offline viperidae
Re: Design help for "smart switching" battery charger for DIY speaker. BMS?
« Reply #1 on: October 10, 2021, 12:26:00 am »
You're probably going to want a low voltage cut off, SLA batteries have their life shortened every time you discharge them completely.
The capacity is also dependant on discharge current. A 4.5ah battery is only 4.5ah when discharged at 225mA. If you discharge it at 4.5A, expect something more like 30 minutes.
« Reply #2 on: October 10, 2021, 07:12:48 pm »
There is a low voltage cutoff in the block diagram, but im into the idea of ditching the SLA all together and running a lithium cell pack and that "smart charger" deal that im not sure if its just a BMS or what
