Author Topic: define PWM input for step response....  (Read 961 times)
Offline ammjyTopic starter
  • Country: kr
« on: April 08, 2018, 12:41:43 am »
Hello, EEVBlog Users ! Thanks you for click.
i don't have idea how i can define PWM input for matlab system identification toolbox.
i'm using matlab "system identification toolbox" for get transfer function of RC servo motor.
i already get very nice step response result of RC servo with 1->2ms PWM signal.
the problem is this..
input signal is PWM 1->2ms signal.
if, input signal is kind of voltage change like a 0 -> 5V. i can get transfer function directly.
but this is PWM signal...
can i use just PWM directly ? or i should convert PWM to some numbers ?
Offline Nitrousoxide
Re: define PWM input for step response....
« Reply #1 on: April 09, 2018, 01:36:26 pm »
Just an idea, perhaps you can convert the PWM signal to a control voltage by performing a low pass on the PWM. However, this will introduce a significant delay and attenuate any high-frequency changes, which may affect your input step signal.
Ideally, you would record the control voltage before PWM modulation.
  • Country: kr
« Reply #2 on: April 09, 2018, 08:30:39 pm »
Thanks you Nitrousoxide !!
i already solved !
Thanks you for your comment.
in this case, i just use angle command.
i mean..
i gve 0.25 number for 1ms PWM.
then i can use just 0.25 !
Thanks you !
