I decapped another one, a Fairchild TL431, so this can work on brand name chips as well. Took half an hour, probably because TO92 is thicker than SO8.
Temperature is stabilized by the boiling liquid, which absorbs excess heat and vaporizes. You just need not to go too crazy with heat input so that the vapor has a chance to recondense before escaping into the air. Watch the test tube and make sure that there isn't too much foam and that the white mist above the liquid isn't rising too high. Pretty simple. Below you can see what it looks like - the green stuff is the overheated colophony (little of it left at this point), yellow is foam, white is the condensing mist which is supposed to be falling down back into the liquid.
![](https://www.eevblog.com/forum/projects/decapping-and-chip-documentation-howto/?action=dlattach;attach=2312317;image)
I put a chip (LT1021) into the flame of an ordinary gas oven in my kitchen till the epoxy became fragile (was almost red), the chip simply dropped off the crust after I pressed it with pliers a bit..
You can, but anything that produces cleaner, more repeatable results with less risk of overheating the die or losing it inside a chunk of epoxy falling on the floor is welcome. Unfortunately, the chips aren't coming entirely clean form this and the colophony gunk isn't the easiest thing in the world to remove and I ended up scratching this die a little. Acids are cleaner, particularly HNO₃.
I wanted to say that one could use colophony to decap chips with the package leadframe and bondwires intact, but the damn die fell off during the boil. Well, at least I have a picture of the package
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
![](https://www.eevblog.com/forum/projects/decapping-and-chip-documentation-howto/?action=dlattach;attach=2312321;image)
