Indeed. But anyway, as ogden said, the main issue is with the values of R1 and R2. Way too low, so they load the boost regulator way too much. I simulated the op's circuit with 172k and 107k instead and it appears to start correctly and get stable in approximately 1.5s with some minor ripple. So the feedback resistors were the main issue.
Still, the output current it can deliver will be pretty limited (as the low-value feedback resistors showed).
