Author Topic: DC-DC recomendations for PMA5-83-2W+ sequencer  (Read 285 times)
Offline john23Topic starter
  • Country: aq
« on: June 14, 2024, 05:03:00 pm »
Hello,I need to build a sequencer for by the guidelines below..
Given that i have +-12V voltage supply.
questions:
1.What DC-DC do you reccomend me to use to get the +5V needed for the amplifier?
2.given that i control the system with microcontroller , what is the best wat to measure the current going threw the amplifier and control the Vg1 accordingly?
Thanks.
https://www.minicircuits.com/pdfs/PMA5-83-2W+.pdf
Offline xvr
  • Country: ie
    • LinkedIn
Re: DC-DC recomendations for PMA5-83-2W+ sequencer
« Reply #1 on: June 14, 2024, 05:46:38 pm »
You don't need DC/DC - maximum load current for +5V is just 4.5mA, so any linear regulator will be fine. Use one with EN signal to turn on/off +5V voltage (VG2).
Much more problem will be with VG1 (-2V). It should be adjusted in range -2V till -0.5V during startup. I think you need some DAC (it cound be real DAC or just PWM + RC filter) and invertor (on opamp) to perform this task.
You can use any current sense amplifier (from specialized IC to shunt resistor and instrumentation amplifier) and ADC
  • Country: aq
« Reply #2 on: June 15, 2024, 08:14:35 am »
Hello XVR, could you reccomend me such device  a 5V regulator with Enable pin?
"linear regulator will be fine. Use one with EN signal to turn on/off +5V voltage (VG2)"
Thanks.
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #3 on: June 15, 2024, 11:03:19 am »
TAR5S50TE85LF
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #4 on: June 15, 2024, 12:42:37 pm »
Opamp for negate Vg1 - TLV9301 (can be powered from +/- 12V rails)
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #5 on: June 15, 2024, 01:08:25 pm »
Current sense amplifier - INA21x, LT6119
The following users thanked this post: john23
