Author Topic: FM transmitter. take current dunt transmit  (Read 939 times)
Offline dave_j_fanTopic starter
  • Country: in
« on: September 10, 2016, 05:19:24 pm »
i took this small and handy circuit :
http://electronics-diy.com/solar-powered-long-range-fm-transmitter.php
but when powerd from 9v cell it is not sending any xmission ... is the schematic ok ?
i feel like the trimmer from OSc is at wrong place
how do i debug it ?
it will be part of walky talky for a low range like 100m
Offline Audioguru
Re: FM transmitter. take current dunt transmit
« Reply #1 on: September 11, 2016, 12:28:17 am »
Your circuit assembly is missing all the important capacitors.
The coil L1 connects from the oscillator collector to +9V and the tuning capacitor connects from the collector to ground. But at 100MHz the +9V is the same as ground so the tuning capacitor and coil are  parallel.
