Split off from another thread I didn't mean to hijack.
1) just use the main rotors for lift and maximum stability (on a very wide arm base), and use two additional propellers to push the copter forward. I'm guessing this would give it a much better stable video platform.
Actually that becomes quite difficult because you'll need a reversing brushless motor controller in order to stop. Also, you'll still have to provide a mechanism for tilting the copter in order to turn. Simply yawing by using two forward thrust motors and differential control will see your quad skating sideways instead of changing direction very well -- a bit like a hovercraft is very poor at negotiating turns.
That might actually turn out to be rather desirable?
I want the effect of the camera kind of "floating" through the canyon instead of obviously "flying" though with great precision.
A better way is to do what the Chinese do with the T580 quad and that's to use the accelerometers and gyros to not only provide a stable platform but to also automatically tilt the camera platform to compensate for any tilting of the quad itself. If you tilt the quad forwards to travel forwards, the stabilized camera platform automatically tilts up so as to ensure the camera remains horizontal.
Yeah, I've seen that. My idea was to just try and eliminate that and make it simpler, because I don't have the same performance requirements as regular quadcopters.
I need it to do just one specific task, get one continuous shot through a complex canyon.
2) Fully autonomous, able to maintain a (rough) height of several meters above the ground, and away from side walls.
That's also been done. Even the cheap T580 has a barometric altitude hold capability and the FyTech 91Q has inbuilt GPS and magnetometer to provide directional hold and position hold. As for staying away from walls -- there are some cheap Chinese hovering toys that do this too, using either ultrasonics or LED proximity detectors.
Yeah, but the devil will be in the detail I'm sure.
Canyons are so narrow (several meters to say 30m wide) with a complex terrain that generally drops (via waterfalls), with all sorts of fallen logs and vegetation on the walls etc.
No GPS reception at all.
I originally thought to just fly a regulator stabilised quadcopter through, but the twisting nature of canyons means you have to "hand-off" control to several people stationed along the way many times as the canyon changes direction and you lose line of sight control. And the complex terrain floor (sometimes with waterfalls you have to jump or abseil, means a single controller following the copter through would not be possible.
I'm probably best just experimenting with a regular stabilised video capable quadcopter first (suitably modified for canyon wall impact and water landing protection) and see what problems actually need to be solved first!
Anyone got any recommendations for a low-ish cost stable video platform system that could be modified like that?
3) Have large foam floats on the base for possible water landings
Haven't seen that yet.
It's for "unanticipated" landings
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
Actually the terrain floor could be anything. Water, huge boulder fields, sand, logs etc.
The goal is to have it autonomously navigate a canyon (and film it). hence no GPS reception, little radio reception, and basically start it at the entrance to the canyon and have to come out the other end intact, without having to follow it on the ground (which is hard and maybe dangerous)
Now you're getting into cruise-missile territory with terrain-following. Uncle-Sam will kick your arse if he catches you doing that, even though you're an Aussie. Look at what they did to me for building a cruise missile in my garage!
[/quote]
Sounds like fun!
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
Dave.
