Hi ElectronSurf
Herewith some comments from me, nice that it works!
Regarding the NE5532, if possible take the NE5532A version, you have more assurance regarding the noise and offset/bias values that they are favorable.
An RC4558 as Kleinstein suggests is not my preference.
One of the few advantages is the lower bias current, otherwise the NE5532A is almost better in everything else.
What I chose it for in one of my designs is its speed and low noise number.
When using the RC4558, the loop compensation will also have to be adjusted again so that the two control loops are again both properly stable.
I agree with Kleinstein, that you could choose a slightly higher value for the current measurement sensor.
So that the Bias currents and offset voltages of the opamp's have less influence.
Think of about 0.33 to 0.47Ohm.
Keep in mind, that by adjusting the current measurement sensor you may also have to adjust the loop offsets maybe a bit again.
That includes C19 and C21.
Also, the chosen rectifier diodes as Kleinstein indicates is on the edge, at voltage spikes on the mains, so can die too easily.
Maybe I pointed it out before, your reference voltage at 2.49V is a bit low. I would as in my versions of the schematic, take 5 or 10V if you wanted to get above 30V with this schematic.
You are amplifying the noise from the reference at higher output voltages quite a lot now.
That makes the noise and hum behavior of the power supply worse than necessary.
Also, I would at least include an additional RC filter for the reference diode,
So before R1 another resistor and an electrolytic capacitor so that the noise signal at that point goes down further.
The Resistor R1 of 1K along with the Ri of the LM336 may not be enough to adequately suppress the interfering signal from the 7808 regulator.
I certainly don't mean that the setup is that bad, it's already much better than most regulators I see coming by. :-)
Kind regards,
Bram
Translated with
www.DeepL.com/Translator (free version)
