I'm part of an electric vehicle club at my school. In the fall we plan on partnering with the schools formula SAE team to build an electric car. I'm trying to come up with a source of lithium ion batteries. The battery pack needs to be along the lines of 240V at 10Ah
Let me do some quick 'cigarette packet' math here (as I think I am going insane?)
240V at 10A = 2400VA which is somewhere surprisingly close to 2400Watt?
Now, I'm an 'old fart', so I still have a brain that works in old fashioned horsepower.
1HP is about 748 Watt (let's round that off the 750Watts to make it easier).
Am I correct is thinking you're trying to build a 3HP car? Good luck with that!
Perhaps you're intending consuming batteries at a much greater rate? Let's get really radical and jump up an order of magnitude to 100 amps.
You've now reached a fairly ACCEPTABLE 30HP output which will at least get the car moving about.
But there's a slight problem I see in doing this. Your battery pack will be somewhat flat before you get to the end of the driveway (let alone around the block).
One of my ummm 'hobbies' was an involvement in the drag racing scene. When I was living in the states, I was intrigued by a group named NEDRA (National Electric Drag Racining Association). These guys have since been merged into the more traditional NHRA drag racing fraternity .
The controllers they use on these suckers are rather impressive such as the 'zilla' controller. At the top end, it is switching a couple of KILO-AMPS at over 300Volts!!! (Think of some SERIOUS IGBT transistors in there doing the switching!). They don't use cables much. Instead, it's thumping great lumps of copper bus bar! They need to run some BIG fans on the commutator of the motor as the plasma production is rather prone to cause some minor ummm 'shorting' issues (and when you have a short on a 500kW power source, things get rather warm in a BIG HURRY.
Last I heard, they've got these suckers running 1/4 miles in just under 7 seconds which is still quite a lot slower than the fastest piston based vehicles (4.5 seconds or so). One of their stumbling blocks is that as the motor reaches high RPM, the back EMF is progressively more difficult to overcome. They often use a PAIR of 12V motors (albeit with a 'special' wind), and they take off from the line with the two motors in SERIES across the 300+ volt supply. Part way through the run when the back-EMF becomes excessive, the two motors are switched from being in series, to being in parallel (simply so that the controller is still able to jam in more amps).
Anyway, you might want to consider 'up-rating' your battery pack(s) somewhat if you want to get anywhere decent.
