Hello there,
The diagrams below are taken from this schematic:
Full schematic. Today, I was adjusting the output amplifiers. Unfortunately the test probe slipped off a test pin and shorted a few of the test pins highlighted in this diagram:
I am pretty sure it was pin 2 and 3 which were shorted for a moment
, (clearly connecting the -45V rail to ground). Immediately after, I noticed that other power rails were low and two massive input resistors in the fuse board (R601 and R602) were starting to smoke so I immediately pulled the power cord. Heres the board with the resistors:
This is what I've found so far:
> I made a few other measurements, and I've noticed that right now, got 0.5 ohm between pin 2 and 3 marked in the top-most diagram.
> I didn't blow the two fuses on the fuse board, they measure .2 ohm and the smoking resistors seems to have the correct value. Since the resistors are smoking, the -45V must be lower than -24V, which is what the relay RY601 bypassing the resistors on the fuse board is rated for. So I assume something is shorted.
Using this information, are you able to suggest what needs replacement or which other measurements it is wise to make?
I have some extra material, here's the
full schematic and
this is the service manual for it. Hoping to get some help
Thank you for your time.
Kind regards,
Marius
EDIT: I measure .2 ohms between the collector and the emitter of Q354, could it be shot? How would we explain that happening?
