Author Topic: DAM11W1S connector dimensions (for SRS PRS10 or Efratom FRS)  (Read 587 times)
Offline matthuszaghTopic starter
« on: March 03, 2023, 07:30:58 pm »
I'm designing an adapter board for an SRS PRS10. This uses an ITT Cannon DAM11W1S connector. Unfortunately, I'm having trouble finding dimensions for a footprint. There's this document https://www.mouser.com/datasheet/2/578/ITT_Cannon_D_Subminiature_Products-1869325.pdf, but I don't see footprint dimensions in there for this part.
I have a part in front of me, which I can measure, but it would be nice to have the information in a technical drawing to be sure.
Does anyone have data on this?
ITT Cannon provides a 3D model by request only. If that works, I'll post the results here.
« Last Edit: March 04, 2023, 05:26:12 pm by matthuszagh »
Re: DAM11W1S connector dimensions (for SRS PRS10 or Efratom FRS)
« Reply #1 on: March 04, 2023, 05:28:25 pm »
This catalog has the footprint (https://www.mouser.com/datasheet/2/578/ITT_Cannon_D_Subminiature_Catalog-1549782.pdf). I've attached the relevant info here. The signal contacts are 0.030in. I believe the part number for this is DAM11W1SN. I don't know what the part number for the PCB version of the coax insert is.
« Last Edit: March 04, 2023, 07:26:43 pm by matthuszagh »
Offline aholtzma
« Reply #2 on: July 04, 2023, 04:03:15 pm »
The Molex part numbers for this are:
1731070074 body
1731120048 plug
I built one of these PRS10 breakout boards a while ago and those are the exact parts I used. I should put the Eagle files up on GitHub.
