Hi all!
I don't know how widespread this technique is, but I thought I'd do a little writeup, since I have come to rely completely on this for making front panels and the like.
Any thickness of aluminium sheet can be cut with a regular box cutter. It works flawless even at 3.5mm plate. Scribing a line along a steel ruler with a box cutter (use the thicker bladed single-blade ones, not the snappable). Scoring first lightly, then deeper and deeper, ending with 5-6 good deep scores on each side (and a few along the edges).
The sheet can then be laid on the edge of a table (ideally clamped down, but with thinner stock it can be done by hand. With very thick sheets needs to be in a vice), longest piece sticking out, and wiggled lightly, then stronger, then bent back and forth, making sure to stay in the range where the undamaged sheet springs back. at some point the sheet will yield along the scored line, giving a cut so clean the only variability seems to be the grains of the plate.
It amazes me every time how well it works. Aside from layout tools, I use only a knife and a step drill for front panels nowdays!
in summary, cutting aluminum sheet with a box cutter:
- Score lightly on all sides of sheet
- Score heavily 5-6 times
- Wobble and wiggle the sheet slightly along the scored line
- Increase the bends as you feel the material yielding.
- Clean edges by draw filing if desired.
Issues:
* The blade can easily slip and cut fingers! Be careful! Establish a score and gradually put more force into the cuts.
* Blades dull very quickly, as you can imagine.
The width of cut is very small, maybe 500 µm- 1mm. Better than a hacksaw, cheaper than a plate sheer.
Hope you enjoy! I'm thinking about throwing together a demonstration video.
--Chris
